1934 TILLEY FL4
Discussion in 'FL1-FL2-FL3-FL4-FL10' started by pete sav, Sep 23, 2010.
  1. pete sav
    pete sav Founder Member
    This is a tilley FL4 floodlight projector this ran concurrentely with the FL3 but the 3 did not have tilt trunions. It was sold by tilley from back end 1933 until 1935 when the FL5 came out.This model was the first with the new steel tank earlier ones used a tank as on the PL55s. This model uses a big clip inside the door to hold the glass not the bolted ring as on later FLs, uses a long narrow bore pump with baynet one way valve.
    1285264594-IMG_1367.JPG 1285264605-Img_1368.jpg 1285264616-Img_1369.jpg 1285264633-IMG_1370.JPG 1285264643-IMG_1371.JPG 1285264652-IMG_1372.JPG 1285264662-Img_1373.jpg 1285264680-IMG_1374.JPG 1285264697-Img_1375.jpg 1285264720-IMG_1377.JPG
