Hello, Yes I know it's another Coleman 237. I found this 237 on one of my excursions to Canada. The owner stated the lantern was in good working order. Well that turned out to be quite the joke considering the control valve was bad. I found a good replacement at old Coleman parts. Today I finally got around to fettling my 237. Well needless to say it is truly in very good working order now. The hood had seen better days but it still does what it is suppose to do. The fount is in pretty good shape but did notice some repairs on the bottom of the fount. As can be seen it looks like it was made May of 1952. Has the original globe. The collar doesn't have an A or B. Here's some action shots. This 237 runs great. Cheers, Norman
I am fortunate to have two of them. If I need a lot of light without any fuss.... cometh the hour cometh the Empire!
Yes there are 2 coins soldered onto the bottom of the fuel tank/fount and this done by the original owner. It's not pretty but it does the job quite well. Cheers, Norman
Probably those two coins serve as some kind of patch. Probably a small leak in the bottom. These 237s are a real workhorse and built like a tank.
I bet the coin was meant to be some 'good luck' trinket of sort.(I mean, other than just as a patch for a leak).
