1955 Coleman Model 236 Major
Discussion in '236, 236A' started by Chris W, Mar 8, 2011.
  1. Chris W
    Here is a Canadian Coleman Model 236 Major, dated 8/55. Note the Black Bakelite valve wheel, which has a brass insert. Displayed here with its original sunrise globe and period No. 1111 mantle.
  2. Chris W
    The ventilator seen here is Pastel-Green, or Light Green, in color. I have recently been led to believe that Coleman of Canada phased out this color in favor of a Dark Green ventilator, sometime between August of 1946 and late 1947, with the last of the factory parts being used by 1948. Due to the heat stresses of these larger models, the ventilator enamel would sometimes be compromised, and replacement ventilators would then be installed. Being a 1955 example, this lantern should probably have a Dark Green "Early-Style" ventilator.
    I have not seen any direct references to support this transitional period as of yet. Any comments regarding this period of change would be greatly appreciated, for the benefit of the community.
    Chris W - Winnipeg, Canada
  3. longilily
    Dungeness
    Crikey Chris
    Seems that late friday night session in the workshop has certainly paid off for you,You were right about those layers of crud too, Looks in showroom condition !
    Great job and Well done
    Ray Al
  4. Chris W
    Thank you!
    Nice to be able to share it with the community - and learn a bit too.
    Chris
