1961, KL.,80.
Discussion in 'Harp Lamps (KL)' started by JEFF JOHNSON, Mar 27, 2012.
  1. JEFF JOHNSON
    This photo shows another of my KL-80 lamps, the tank is marked 161, which is January 1961. Jeff.
  2. longilily
    Dungeness
    Jeff
    Excuse my ignorance here, Is that the correct heat deflector for the year, or is it a substitute/alternative 'pringle'?
  4. longilily
    Dungeness
    Got it !
    Thanks for the info Jeff
  5. David Shouksmith
    Another little metal spinning project..? :whistle:
    If you have one of the Tilley (Pork Pie Tank) lanterns which have the brass hood, then the heat deflector on said hood, is exactly the same as the heat deflector for this period of KL-80.
    Except that it's made of steel rather than brass, but it would make a perfect template.
    The link below shows what I'm on about, Jeff.
    1947 Tilley X246
  7. longilily
    Dungeness
    Thanks again Jeff !
    I don't have 'said top' ! Its rusted away being steel, but i do need to replace it with a brass one, and interesting to know it also doubles up as a KL80 heat deflector
    I think so David! I do like a challenge ;)
    Think those pringles would be interesting to make too
  8. JEFF JOHNSON
    If you have any broken PL-53 handles, then the brass rod from them is good for making the hanging rods for the KL-80 heat deflectors, Jeff.
  9. longilily
    Dungeness
    I Don't Jeff, but brass rod isn't a problem to obtain locally
    Thanks for the info
  10. David Shouksmith
    [johnlaurievoice]Och, aye - but then ye'd hev ter pay fer it, Ray - Hoots mon..![/johnlaurievoice] ;) :lol:
  11. Jean J
    David, what a rubbish attempt at a (written) Scottish accent. I would stick to the King's English if I were you!
  12. David Shouksmith
    Queen's English if you don't mind, Jean - 50 years on the throne this year...
    Anyway, give order, otherwise I'll have no alternative but to post that picture of me in a kilt again. :twisted:
  13. Trojandog
    Trojandog Subscriber
    Er..... 60 years actually.
    Off with your head.
  14. David Shouksmith
    Does that mean I've missed the Golden Jubilee, then? Awwww... :doh:
    Yes, meant 60 years of course - I was obviously distracted by the thought of that kilt and the wind blowing free around the Trossachs. ](*,)
  15. longilily
    Dungeness
    Are those round heat deflectors/early guardsmen tops beaded at the edge (As in the edge doubled back on itself-normally for rigidity)? or just an open edge ?
  16. David Shouksmith
    It's a plain edge, Ray:-
    For some reason this one was already detached and just sitting on top of the ventilator. Just shout if you want it sent down - it's a rough old dog but should suit your purposes...
  17. longilily
    Dungeness
    Yes please David, i do need to make one for my early guardsman, and would be nice to have it as close to the original as possible
    As and when you find the time !
  18. OZZY
    I'd be intrested to know how you would make one of these Ray as I need to make one myself.
    Ozz
  19. longilily
    Dungeness
    Hi Ozzy
    I'm not totally sure yet mate, probably a press tool judging by its mild shape ???. I intend to have a play at work as and when i get time. When i do though Ozzy i'll let you know if you like :D :D
  20. Matthew92
    Matthew92 Subscriber
    If you go into mass production I could also use a couple ;)
  21. David Shouksmith
    Hopefully, tomorrow.
    You'd better put me down for a dozen or so... ;) :roll:
  22. Matthew92
    How do you find the room David? :lol:
  23. OZZY
    Thanks Ray. I had thought of the press Idea and I have access to a press but I'm not clever enough on a lathe to make the Dies
    Ozz
  24. longilily
    Dungeness
    Ok chaps Fingers crossed then [-o< [-o<
    Sorry about your KL80 thread Jeff :-&
  25. JEFF JOHNSON
    No worries, it's sparked some interest which is great.
    I have a spare first version of the pork pie tank lantern, but I have not had a chance to restore it yet, Jeff.
  26. David Shouksmith
    I just got rid of the wife - she and her things were simply taking up far too much space... ;) :lol:
    BTW, Ray, the sample went off 1st class today.
  27. longilily
    Dungeness
    Ok Thnx :thumbup:
