1977 - Tilley X246B
Discussion in 'X246B' started by sharkdark, Jan 19, 2023.
  1. sharkdark Australia
    Adelaide
    is this fixable and can parts be purchased to get it up and running thanks Markc.
    Yes. It’s fixable.
    It’s a model X246B but it has the X246 pump (which is better than the X246B pump).
    First, make sure the bottom plate of the tank is not touching the flat surface when the lantern is sat down. This shows whether the tank has been over-pressurised or not.
    Parts are available from TW Sands in Melbourne.
  3. sharkdark Australia
    Adelaide
    Thanks for the reply Tony press, if I pump the tank and turn the knob I hear air so it is obviously holding pressure ? can I fill it and light the burner to see if it works without a mantle , sorry for the questions but I am very new to these lanterns , kind regards Mark.
    Check for air pressure leaks first (soapy water). Check your pump washer is not hard.
    You can light without a mantle, but at low pressure.
  5. sharkdark Australia
    Adelaide
    does anybody know where I can buy a 777 control cock from please im in australia cheers
  6. Tony Press
    Do you need the whole control cock?
  7. sharkdark Australia
    Adelaide
    ive just ordered parts through Tilley int cheers Tony.
  8. sharkdark Australia
    Adelaide
    thanks mate
  9. Henry Plews
    The insect screen is upside down and needs to be turned over otherwise with a glass in place, you won't be able to clip the preheater torch onto the vapouriser.
  10. sharkdark Australia
    Adelaide
    thanks Henry will do!
  11. Buggerlugs
    Excellent advice as always, looks like you have a very nice lamp.
    If you look underneath the fount (tank) you will see some numbers and letters, the numbers will tell you the date and the letters not too sure what they mean.
    For example 0970XA means September 1970.
    Enjoy it.
  12. sharkdark Australia
    Adelaide
    mine has 177 on it ?
  13. Tony Press
    That should be January 1977. Do you have a photo of the stamp?
  14. sharkdark Australia
    Adelaide
  15. Tony Press
    January 1977.
  16. podbros
    Hi Mark !
    Nice Chrome/plated Tilley there
    that should clean up well
    regards
    pb
