AGM SunFlame
Discussion in 'Fettling Forum' started by Darryl Durdin, Apr 30, 2021.
  1. Darryl Durdin
    1B439EC9-B19B-4208-857D-3AFA8F797445.jpeg Hi fellas, I’m working on fettling the sunflame, I’ve come across a few things that I need help with,
    8EDAB1E4-53C0-4B27-8C41-855280ED22B8.jpeg 43A3F267-EC05-4AA7-9C5C-374A98287C85.jpeg
    this is the pricker lever, it was sieved, I used the heat and quench technique a fair bit, the end was not pretty, it did come out but the graphite pacing came out crumbled, I cleared it out,
    Is there a replacement item that will work or an alternative?
    the mesh flame spreader had disintegrated, I cleared it up, is there an alternative for the mesh,
    It’s a cool lantern and I hope to ge it going again
    Thank you for your help
  2. ROBBO55
  3. Darryl Durdin
    @ROBBO55 hi there, I’ll have to measure, the agm was a wire mesh with what looked to be held in with some sort of circlip
    Tony Press Antarctica Subscriber
    Darryl
    Graphite string or a thin slice of graphite tape should work for the packing.
    You could use brass or steel mesh of a similar weave for the burner cap, but Martin has made a few that fit Austramax from speaker covers.
  5. ROBBO55
    Darryl, OK, I wasn't sure which construction the flame spreader was. Some in the reference gallery looked like pressed metal.
    I used a kitchen strainer on this Austramax 3/300 Lantern with Red Hood and all brass font.
    The wire was o.22mm dia and 0.7mm between strands.
    You should be able to pick up a suitable circlip from any auto supply shop.
  6. Darryl Durdin
    @Tony Press , @ROBBO55 thank you for your help very much appreciate, I’ll be sourcing what I can find I like being resourceful
  7. Darryl Durdin
    My burner has an inside diameter of 21.5mm, I bought some of this mesh used on a stove toaster
    I’m hoping this will do the job,
    Now looking for some graphite tape.
  8. Fireexit1
    Do internal circlips keep their temper ? I guess not so important until the mesh wears out and then you put a new one in ?
    Good find tho Darryl !
  9. Darryl Durdin
    I repaired the burner mesh cap with the steel mesh from the camp toaster, I used tensile wire as the keeper clip 8D362584-1062-4255-A7CE-987782093E61.jpeg
    I repacked the pricker lever with some graphite string
    I cut fine brass mesh and fitted to the fuel pick to replace the old mesh F7ACF6F1-3F05-474F-A65A-CA41CBE5E6AE.jpeg 3132F0AE-10A8-47F9-A03F-4C7120B6B9BB.jpeg
  10. JEFF JOHNSON
    It's progressing.:thumbup:
  11. ROBBO55
  12. Darryl Durdin
    Hi fellas I’m going to see if I can replicate the Sun Flame badge on the collar, I have a local sign writer who ca scan and print out the label, can anyone help me out with a picture of the sunflame badge in good order 8B1EB899-CAF7-4DAE-B7D9-C3C43B1B0A05.jpeg
