Akron 132-42 with Aladdin 1944 Mil-Spec Conversion
Discussion in 'Milspec Lamps' started by Alex Smith, Apr 3, 2020.
  1. Alex Smith
    Midlands, UK
    Akron 132-42 with Aladdin 1944 Mil-Spec Conversion.
    Have focused on a simple clean following a strip down. The lantern came from a seller in France, and is pretty much as it arrived - less rust removed. It is fitted with a AGM Hood, secured by a nut. The globe is a modern 220/295 glass. Running on Aspen 4 fitted with a Silk-Lite #21 Mantle. As ever lighting is more "Art than Science"!
    Base of Fount - Stamped as follows: "US", "The Akron Lamp and MFG. & CO.", "Akron, Ohio"
    The collar is coated in rust. Much has been removed, however the Maker Plate attached would lose its remaining text if treated too harshly. I have oiled the collar to try to preserve the plate.
    This is a example to show the full lettering on the plate:
    Blue flame test showing burner assembly without the cage fitted:
    Bottom of Burner Assembly 1. Text reads: "ALADDIN CONVERSION 1944"
    Base of Burner Frame:
    Compassion between Akron 132_42, US Military issue (i.e. stamp US on base of fount, but with a 220 double mantle burner assembly) and Akron 132_42 with Aladdin Conversion 1944 to Mil-Spec:
    They are working well!:thumbup:
  3. AussiePete
    @Alex Smith
    A good a solid restoration whilst preserving the patina of time and use. I enjoyed reading your description of fettle.
    Well done.
    I too like these old war horses and one day, one day I’ll find one in the wild.
