Bialaddin NRV
Discussion in 'Fettling Forum' started by Johnny19, Mar 7, 2021.
  1. Johnny19
    Johnny19 United Kingdom Subscriber
    Liverpool
    Hi all, maybe a stupid question here. I recently replaced an NRV pip on a Bialaddin 305, and all working fine now.
    When i took the NRV out there was no rubber washer present, so after doing the job, i just put back in.
    Admittedly I had to clean some gunk from down the tube where the valve sits. Question is, should there be a washer in there?
    Cheers all......
  2. Fireexit1
    Yes - part no V33 I think - should have been in the kit ?
  3. Johnny19
    Liverpool
    @Fireexit1 Cheers, best get it fitted then. ( I have a tin of Vapalux/Bialaddin washers various sizes). Thanks again.
  4. Henry Plews
    Ideally yes (part number V33). I've known the washer stick to the bottom of the tube rather than the valve - perhaps only two or 3 times but it has happened - perhaps the gunk you cleaned out of the tube was the perished remains of the washer.
    Edit: crosed with @Fireexit1
  5. Johnny19
    Liverpool
    Thanks Guys, job done. All I have to do now is sort out the vaporiser as It's a very feeble light. The Tank is spotlessly clean, but while I'm at it I'll also check the Jet Cleaner assembly also......
