Bialaddin pair and others...
Discussion in 'Fettling Forum' started by Alex74, Oct 11, 2020.
  1. Alex74
    Faringdon, Oxon
    Just finished fettling another two wrecks. The cage of the Halifax was shot and loose, so I found a steel slotted one (with brass rods) Which I stripped and polished (it was very rusty and the paint was peeling off). The fuel cap says ‘Vapalux Halifax Eng’ on it. I haven’t seen one like it before. The heat deflector is a modern replica I got from Juliand. The other lamp is a standard 300x and that’s how I got it minus rust, cobwebs, flaking paint and grime. Is the Vapalux reasonably ‘time correct’ with that cage or not? I know the tank should have been bigger ( like the ones on the E41) and the globe should have a lighting hole)? I’m still waiting for a set of seals from the FB. I think they make a nice pair. I love running lanterns in pairs side by side. Slightly different models but in almost identical pairs. Just like the PL53s I have: brass and steel tank, burning side by side. The next fettle is a an X246 pork pie with removable cage, to provide a pair buddy to the short bail one I have! Take 2...! Pairs! Due! 9E7212A6-8456-4166-BF0E-4A1B7DA82AD7.jpeg E1FC3E62-C65A-4532-8AA6-F27ACCAF3A3F.jpeg 52F8EC04-8D4C-4D0E-AEBA-7A096A99D2E9.jpeg 08BCE832-E2E9-4453-A18E-346B193067CF.jpeg 67251C62-6ACD-4A3A-A9BE-786A95D0F346.jpeg
  2. Fireexit1
    Nice pairs !:)
  3. Gary Waller
    Gary Waller Subscriber
    Hi @Alex74
    Originally the slotted frame would have gone with the wider, dumpy tank, and the glass with the hole in. Your tank is a later 300X.
    The stamped fuel caps turn up now and again and are probably from the earliest 300s you’ll note there is no split pin on the air release screw... This my unrestored version, sadly glass is cracked.
    8EB9D8C9-D650-4A1B-B259-55C6ED8EE4EC.jpeg F1D1B324-F4BC-4681-9F35-B90D73104A56.jpeg
    A fine light up!:thumbup:
  5. george
    Great light up! Very nice, love those Vapalux/Bialaddin's!!
    :thumbup::thumbup:
  6. Alex74
    Faringdon, Oxon
    Thanks Gary,
    now I need to find an original tank then...And a globe with the hole..!
  7. BigStevie
    Great lamps and that’s a comfy looking shed!
  8. Alex74
    Faringdon, Oxon
    Got to be careful not to set that shed alight with all the lamps Lit in there! :shock:
