Blanking stopper for a Tilley.
Discussion in 'Fettling Forum' started by ColinG, Mar 28, 2020.
  1. ColinG
    I sacrificed an old vaporiser to make one of these so I can use the ice trick to remove dents from founts. The central hole is almost exactly 2.5mm which is perfect to tap out to 3mm.
    With a 3mm machine screw tightened into place I expect it to hold pressure but if it doesn't I can always add a blob of solder to the top.
    I bought a job lot of old vaporisers and control valves a while back thinking they'd come in handy!
  2. george
    And it looks like it paid off! :D/
  3. Norman
    Spokane, WA
    Well done Colin.
  4. ColinG
    I have a dented 246a fount that I'm testing first to see if it works.
  5. ROBBO55
    Looks like it should do the job nicely. :thumbup:
  6. Darryl Durdin
    Great idea, thank you for sharing, i am going to try the freeze test on a dented kayen that i have. To practice on
  7. AussiePete
    What a good idea @ColinG
    I'm gunna make one, thank you for sharing.
