Built in lighting torch.
Discussion in 'BR49-BR49A-BR49B' started by Lewis Hillier, Mar 30, 2018.
  1. Lewis Hillier
    Hi Guys,
    This lantern has a built in lighting torch, using the fuel from the main tank. I've not seen it before, can anyone Identify this lamp?
  2. David Shouksmith
    Tilley BR49 with a knackered top and home-made handle on the pre-heater shroud:-
    Tilley BR49
  3. Lewis Hillier
    Thanks! Nice lamp you have There.
    A fine restoration project!:thumbup:
  5. Lewis Hillier
    Well it is for sale if you fancy it!
  6. WimVe
    So you are noy a collector but a seller ?
  7. Lewis Hillier
    Well I actually bought the lamp to use. When I was younger my dad always used one on our camping holidays, and I wanted to do the same. I never got it fully working, so used it as an ornament really in my study. My dad had a red X246. I am interested in the lamps, just not an avid collector, I have a Coleman lamp with two mantles that I use for camping.
  8. WimVe
    Nice ! why didn't you get this BR49 working right then ?
    It is a rare beast, so worth keeping.
  9. Lewis Hillier
    I did buy and fit most of two service packs i bought online, leather bits etc (I'm sure you know), but it never glowed properly, and then my summer holiday ended and went back to work!
  10. Henry Plews
    Likely causes could be:
    1) Shortage of fuel due to an obstruction between tank and control cock.
    2) Build-up of carbon in vapouriser is restricting fuel flow.
    3) Obstruction in one or more of the air tubes - even a spiders nest will make a difference.
    4) Hole in vapouriser has become enlarged.
    Both 3 and 4 will make the fuel / air mixture "rich", usually accompanied by yellow or red flames outside the mantle followed by black spots of soot.
    Any chance of a picture of it "not glowing properly" ?
    Henry.
  11. AussiePete
    My two penneth worth. Worth keeping and restoring. I have one myself and I like the unique preheating method, I light it now and again because ........ I likes it!
