Ca. 1930 Succès 156 parabolic heater/stove
Discussion in 'Guenet & Abbat' started by Conny C, Jul 28, 2013.
  1. Conny C
    Conny C Sweden Subscriber
    Hi all,
    This is a gasoline fed parabolic heater that is 3 in 1……… a table heater, a wall heater and it can also serve as a stove. It has a flexible and adjustable parabolic disc that is changeable in 90 degrees. I believe this is a transition version of the 1926 and 1932 Succes heater from the Paris company of Guenet & Abbat. Looks very similar to the 1932 with the same fount and wire guard/outer burner cap, but the burner has a few discrepancies. Michel Binard also show here in the French gallery, a kerosene No.178 version of this heater, with a pricker unit below the parabolic disc.
    Do you know how many bits and pieces it takes to assemble a French heater/radiator? Yes, you are right …….it takes seventy.
    I was lucky to have the before pics as reference, when I tried to assemble the heater after cleaning and fettling. I managed to fit all the parts so I believe the heater is complete. It is still running in my shed, although we got a very unusual warm Swedish evening now (tropical night +20C).
    The 1932 catalogue image comes from Neil.
    /Conny
    1374968546-Succes_156_radiator_HEATER_STOVE.jpg 1374968584-Succes_156_stove_position.jpg 1374968608-Succes_156_lit.jpg 1374968627-Succes_156_lit_with_outer_burner_cap_and_protection_guard_.jpg 1374968642-Succes_156_radiator_HEATER_STOVE_lit.jpg 1374968668-Succes_156_heater_parts.jpg 1374968689-Succes_156__burner_unit.jpg 1374968725-Succes_156_burner_with_cleaning_needle_unit.jpg 1374968745-Succes_156_cleaning_needle_and_jet.jpg 1374968769-Succes_156_front_burner_view.jpg 1374968804-Succes_156_fount.jpg 1374968885-Succes_156_plate.jpg 1374968918-Succes_156_side_view_detail.jpg 1374968976-Succes_156_side_view.jpg 1374969045-Succes_156_heater_stove_boiling_water_.jpg 1374969064-Success_1932_Guenet-Abbat_156_radiator_Neil.jpg
  2. John
    John United States Subscriber
    Dallas, Texas; United States
    Another fine restore Conny. :thumbup:
    That's a beautiful heater and the tip cleaning mechanism is a true wonder
  3. Michel
    Michel Subscriber
    56 France
    Hello Conny
    Yes exactly the same as mine, except for the needle's command.
    I see that the tropical temperatures gives you very much energy :clap:
    here we have up to 30 degrees, too much warm to work in the barn
    I prefer the sea baths and sailing
    That a very smart heater/stove and a fine restoration! :thumbup: :clap: :clap: :thumbup:
