Can anyone id
Discussion in 'Pressure Lamp Discussion Forum' started by John pesat, Mar 26, 2021.
  1. John pesat United Kingdom
    Uk
    I have tilley lamp I would like to restore but don't know the model it isn't stamped 1616793634594179308958476247594.jpg
  2. John pesat United Kingdom
    Uk
    Anyone any idea which model so I can service and restore
  3. Gary Waller
    Gary Waller Subscriber
    Tilley PL53, it looks to be in nice original condition, a good clean and a new seal kit and you’ll be on your way.
    Yes, it's a WW2., version of the PL-53.
  6. podbros
    ..here
    Hi John and a warm welcolme !
    Nice old Tilley :thumbup:
  7. John pesat United Kingdom
    Uk
    Is it brass or steel should I leave the original finish or polish thanks
  8. John pesat United Kingdom
    Uk
    Cheers so it will be steel then don't want to try and polish
  9. John pesat United Kingdom
    Uk
    Cheers I do a lot of wild camping would be good to get the tilley up and running again
  10. Tony Press
    @John pesat
    If it were me, I would leave the tank with its original finish - just clean it with car cleaner or soap and water, then rub car polish or beeswax to protect the paint.
    Use a magnet to see if it’s steel or brass.
  11. John pesat United Kingdom
    Uk
    Thanks looking forward to using on my camps
  12. John pesat United Kingdom
    Uk
    Thanks Tony
  13. podbros
    ..here
    Did the magnet stick to the tank then John?:-k
  14. John pesat United Kingdom
    Uk
    No its brass must be pre war
  15. BigStevie
    Hi John and welcome to the forum. That’s a nice original looking PL53 lantern you’ve got there. It’s a great feeling when they pop into life!
    Enjoy the fettle, Stevie
  16. JEFF JOHNSON
    The WW2., PL-53 was produced in both brass and steel versions and mixtures of both.
    Wartime shortages meant that Tilley and many other companies used what they had and what they could get.
    The GF., control cock which is fitted to your lantern was first introduced in 1940.
    This link shows WW2., pumps.
    4 Tilley WW2., pumps.
  17. John pesat United Kingdom
    Uk
    Cheers im looking forward to using it
  18. John pesat United Kingdom
    Uk
    Cheers its in good nick for 80 years old now to order a seal kit mantle and pre heater
  19. John pesat United Kingdom
    Uk
    Do I use paraffin in this lamp sorry but not had one before
  20. steerpike451
    Norfolk, UK.
    Paraffin to run it, meths for preheating. I was about to say you'll need a preheater, but I see you know that already!
    Nice find, looks to be in good shape for its age.
  21. JEFF JOHNSON
  22. John pesat United Kingdom
    Uk
    The pipe up to the mantle is a bit rusty I presume this sprays fuel need to find somewhere that does a full service kit now
  23. Graham P
    Graham P Australia Subscriber
    Albury area NSW AUstralia
    The pipe up to the mantle is known as the vaporiser it turns the kero to a gas and contains a (pricker and spring)to clean exterior, if desired with emery/steel wool, they can block internally with carbon where they are heated by the mantle & burner . Test the lamp (with globe removed pressurize with fuel in tank, when cock is opened a jet of fuel should be seen) before attempting to light do a dunk test (submerge pressurised font in water and look for bubbles) leaks
  24. John pesat United Kingdom
    Uk
    Thanks for the help
  25. John pesat United Kingdom
    Uk
  26. John pesat United Kingdom
    Uk
    Ordered thanks
  27. John pesat United Kingdom
    Uk
    Think I need a new vaporiser
  28. Tony Press
    @John pesat
    Why do you think you need a new vapouriser?
    Rust on the outside is no issue - just sand it off. Carbon build up on the inside can be cleaned out.
    But an enlarged jet requires the vapouriser to be replaced.
  29. John pesat United Kingdom
    Uk
    Think the vaporiser is rusted closed at the top
    I'll sand it down and see if the pricker protrudes
  30. John pesat United Kingdom
    Uk
    Thanks trolling eBay as I speak
