Coleman Easy-Lite 222A not working
Discussion in 'Fettling Forum' started by RMTChris, Jul 9, 2021.
  1. RMTChris Canada
    Peterborough, Ontario, Canada
    Hi All, Just got this lantern from someone who has kept this lantern in her basement for the 20 years. Sadly there was fuel in it. So not surprisingly it doesn't work. I emptied the old gas and replaced with fresh coleman fuel. When I pump it up, I can't get any pressure. I'm doing at least 50 pumps. Any thoughts?
    Thank you,
    Chris
  2. Henry Plews
    Hello Chris and welcome. It sounds like either the pump is not working or the rubber seal in the filler cap is not working or possibly a combination of the two. Take out the pump and inspect the pump cup, it's some sort of synthetic material but it could be split or torn and will need replacing. If the filler cap seal has gone hard, it won't seal properly and air will escape as fast as you can pump it in.
    If you have difficulty locating spare parts locally, oldcolemanparts.com could have what you need.
  3. Reppie
    Reppie United States Subscriber
    Bay Area
    One thing to note regarding those 222a other than the pump problem you got, careful of the fluro something o-rings as they will leak over time given how long it was stored or used before storage.
  4. Pancholoco1911 United States
    Get a new leather washer from fettlebox and a o-ring set from OCP.
  5. Mackburner
    These lanterns always worry me. I have three of them and they are neat looking things that look great and work well but I don't like the valve gland O ring seals. Unlike most lamps we play with the gland seal can't be tightened if it leaks. They rely on a ratchet type clip to retain the O ring so the integrity of that O ring is vital. I would strongly suggest replacing the O ring and a pressure test if the lamp has been stored for any length of time. ::Neil::
  7. RMTChris Canada
    This is great!! Thank you for the responses. I guess I will start with the easiest and check the leather.
