Coleman QL 327
Discussion in 'L327, LQ327, QL327' started by Sellig33, Mar 30, 2018.
  1. Sellig33
    Sellig33 France Subscriber
    Arrived yesterday at home ( pictures from Ebay ):
    s-l1600.jpg s-l1600_2.jpg s-l1600_3.jpg s-l1600_4.jpg s-l1600_5.jpg s-l1600_6.jpg
    Missing: pump, ventilator rod and ventilator ball nut.
    Mica chimney to be replaced.
    More pictures later.
    Gilles
    A fine fettling project!:thumbup:
  3. ROBBO55
    Congratulations :thumbup:
  4. Sellig33
    Today, sad weather, sunny & rainy all time. So i work on the lamp, and....
    20180331_162750.jpg 20180331_165008.jpg 20180331_165024.jpg 20180331_165051.jpg 20180331_165106.jpg
    Test sealing, fill with "essence C ( Coleman fuel ) ", pre-heating, and ......
    Next, i put 150 CP mantles, when i got a mica chimney ( i mail to Fred Kuntz, no return yet )
    Are there Peerless mantles of 150 cp ? or i can install 200/250 CP mantle for this lamp ?
    Thanks for reply.
    Gilles
  5. ROBBO55
    Gilles, It has cleaned up nicely.:clap:
  6. Hanzo
    Hanzo Subscriber
    What a restoration, magnificent job. You will love the Fred Kuntz mica chimney, it is just the right finishing touch to a restored 327.
  7. Sellig33
    Thanks all !
    A question, mantles 150CP or Peerless 2C-HG?
  8. bp4willi
    wow, superb restoration.
    well done.
    regards
    willi
  9. phaedrus42
    Well done, Gilles! I would go with the Peerless 2C-HG. You could also fit an R-55 generator if you prefer to have an internal pricker.
  10. Sellig33
    Thanks Willi & Phil.
    Whath do you think of Coleman mantles #20 or #21 ? It would work on QL 327 ?
    Who has recently been in contact with Fred Kuntz ? I don't have an answer from him.
  11. phaedrus42
    The 20 is a bit smaller than the 21 and the recent Coleman mantles have not been the best quality.
  12. Sellig33
    Thanks for the return Phil, so I will stay on 2C-HG
  13. phaedrus42
    You can't go wrong there. The 2C-HG form slightly bigger than the 21A but I do not see that as a disadvantage. There are also some very good vintage mantles around if you can find them: The very old Coleman, Coleman silk-lite and the Veritas Elephant Brand come to mind. I have been left unimpressed by Luxor, Butterfly and in general by most Chinese rosette-style mantles.
  14. Sellig33
    I put Coleman 2C-HG, they are a little big. I have some Petromax 150CP mantles, i'll try later. QL 27 is a 150 CP.
  15. Hanzo
    Hanzo Subscriber
    Sellig
    The Peerless 2C Hg are the right mantles for the lantern or the Coleman# 21 mantle they are equivalent, anything smaller won't work. I am guessing a 327 is 300cp. One thing is your mica is dirty and the lantern will look completely different when you have a new one. I use a modern bicycle pump to add air to the lantern and with a high pressure it works like a machine.
  16. Sellig33
    Thanks Hanzo. Do you know if Fred Kuntz made always mica chimney ? I mail him, but no answer. A friend of mine, mail last month, and no answer too. Fred is still alive ?
  17. Hanzo
    Hanzo Subscriber
    Yes , Kuntz still makes chimneys and many other lantern globes and accessories, he has a catalog . I believe he'll ship abroad as well. The current price of the mica you'll need is $35.His email is here, fredkuntz@adelphia.net
  18. Sellig33
    Hi Hanzo,
    I have the prices 2015 in pdf, do you have earlier in pdf format ?
    I try to mail again.
  19. ColinG
    What an amazing transformation you'vemade and what a great lamp you now have! Well done!
  20. Sellig33
    Thanks Colin,
    I am very happy with myself :D/
    Another question for all: what’s the candle power on QL 327 ?
    Michel thinks it's 2 x 150, me 2 x 300, who is right ?
  21. Mackburner
    They were rated at 300cp. So 2 x 150. ::Neil::
  22. Sellig33
    Hi Neil,
    Yet 2 bulbs of 60W are not 120W ! It's not the same for mantles ?
  23. phaedrus42
    :lol:;) Gilles, I say this in jest, but, if 2x60 is not = 120 then you have just single-handedly and in one fell swoop demolished the edifice of 5000 years of mathematics and engineering ](*,):shock::lol:
    Perhaps you are referring to the illumination provided and not the electrical power consumed?:-k
    Even so, a 2-mantle true 300cp lantern should provide very close to twice the illumination of a single mantle true 150cp lantern.
    The problem is, many manufacturers were referring to very small candles when they dreamed up the cp ratings of their lamps.
    Notable exceptions were the Germans and Swedes:content:
  24. Sellig33
    You're right Phil, i'm referring to the illumination, not consumtion.
    If QL 327 is a 300 CP lantern ( 2 x 150 ), why did we used 250/300 CP mantles ?
  25. phaedrus42
    Hmmm... I see the packaging says 250cp 4-pack but I would take that with the same grain of salt as the lamp company's claim.
    I have noticed that to some extent mantles shrink/form to a different size on different rated lamps, depending on the air/gas pressure, I suppose.
  26. Hanzo
    Hanzo Subscriber
    I will not contradict Neil , he is truly an expert on lanterns and I am very close to ignorant , lol. Here in America though 150cp mantles are not readily available so I use what everyone here uses in all 300 cp double mantle lanterns, Coleman #21 but mostly the Peerless equivalent, 2CHG because they are brighter and whiter. They work fine in my 327's .
  27. Sellig33
    Ok I understand better, thanks all.:thumbup:
  28. Sellig33
    I had my wife at phone, and the mica globe is at home :D/
    Pictures soon !!!
  29. Sellig33
    Unpacking the package last night when I got home from work, I remove all the papers and there :doh: ](*,) two mica panels took a shoot and are delaminated
    Direct contact on Ebay with the seller and photo above to support. Here's his answer " Lovely. I'll open a claim with Canada Post and reorder/resend".
    So in theory, I will receive a new globe (intact ??? [-o< ) in 3 or 4 months. Nice and professional seller :clap:.
    And in place it gives this:
  30. Mackburner
    The Quick Lite lamps and lanterns in the 1920s were advertised as 300cp. There is no doubt that when new they would achieve that. They were also advertised as burning for 18 hours with 3 pints of fuel. 6 hours to the pint is about right for 300cp so I suspect WC was telling the truth. ::Neil::
