Crystal-Lite Model 9 Wall Lamp
Discussion in 'Other Brands' started by Tony Press, Feb 12, 2020.
  1. Tony Press
    Here is my Crystal-Lite Model 9 Wall Lamp.
    "Crystal-Lite" was sold in Australia in the mid- to late-1920s by J&W Bateman Ltd (see here ). Neil McRae has these lamps as the same as USA "Enterprise" lamps.
    The lamp is gasoline.
    The fuel control wheel is marked "THE A. J. ALSDORF CORP./ CHICAGO/U.S.A./CRYSTAL LITE".
    I'm informed that this wall lamp, and its siblings are not at all common.
    I don't have the original shade or mica/glass.
    "MADE IN U.S.A."
    Coleman-like check valve and filler cap.
    As it came.
    Up and running!
    Not the correct shade, but the right shape (approx.)
    With a Coleman shade.
    This was a fairly straightforward fettle. I cleaned up the rust, cleaned the brass tank etc. I left the lamp in the condition it was found, other than the cleaning. I've protected the enamel and metalwork with beeswax. The hardest part of the fettle was feeling very nervous about whether it would run or not. In the end, it was lighted very well, if a bit finicky at first go.
    I am very pleased to have this piece up and running.
    @Mackburner
  2. Norman
    Spokane, WA
    Tony,
    Congratulations on fettling this wonderful lantern.
    She is running well indeed.
    It is also very nice to see a piece of history up and running.
    Thank you for sharing.
    Cheers,
    Norman
  3. Jean J
    What an interesting and gorgeous looking lamp Tony.
    Well fettled!:thumbup::clap::clap::thumbup:
  5. BigStevie
    Great job, great lamp. A real looker!
  6. george
    It's certainly different... A very interesting lamp, for sure.
  7. ROBBO55
    Congratulations Tony :thumbup:
  8. AussiePete
    Congratulations on a fine fettle Tony. It’s another part of our lighting history brought back to be enjoyed by the present and the future. Well done.
    I enjoyed going through the associated pictures, it’s very well documented.
    @Tony Press
  9. James K
    James K Subscriber
    That is a beautiful lamp.
    Well done for finding It, top job for firing it up and thank you for sharing.
    James
  10. Mendoza603 United States
    That is something especial.
    :D/:D/:D/:D/:D/:D/
    ///Fernando
  11. WimVe
    That is different, nice lamp.
  12. Tony Press
    Note:
    The glass/mica/chimney size for this lamp would be 89mm maximum outside diameter X 125mm length (3 1/2 inches X 5 inches).
    The fitter for the shade takes a 90mm diameter shade fitting (5 inch).
  13. AussiePete
    @Tony Press
    You have a typo. 90mm is smaller than 5 inches.
    90mm = 3.5” (actually 3.54”)
    125mm = 5” (actually 4.92”)
  14. Tony Press
    Ahhh.... You are correct. Thanks.
    The metric is what I actually measured, so they are correct.
