Cutting glass globes
Discussion in 'Fettlers Master Class' started by phaedrus42, Mar 8, 2016.
  1. phaedrus42
    I acquired another Primus 1020 and also my first Radius 119 and found myself in need of two more shortened Coleman large straight sided globes.
    This time I decided to try my hand at cutting them myself.
    I used a diamond coated titanium disk in my trusty Dremel tool. I secured the Dremel in my bench vise, clamped an old block battery to the workbench as a guide, and marked the globe in the burner cage of the lamp. Then I turned on the Dremel at fairly low speed and while turning the globe with one hand, fed a dribble of water from a squeeze bottle onto the cut with the other hand. The disc cut the glass like the proverbial hot knife through butter.
    It is a rather messy process with the water spraying everywhere and it seems that a lower speed and shallower cut would give a better result.
  2. patatwin
    Good job !
  3. longilily
    Dungeness
    Nice Phil :thumbup: looks to be a tidy cut :clap:
    Good work, Phil. :thumbup:
  5. David Shouksmith
    Cracking job, that... :thumbup:
  6. Hanzo
    McIverring at its finest.
  7. HighlandDweller
    Great work, must remember that one.
    I wonder if it would be possible to flame polish the edge? I must try that sometime.
  8. kerry460
    kerry460 Australia R.I.P.
    Launceston Tasmania
    very interesting .
    thankyou
    kerry
  9. Scotlamp
    Scotlamp United Kingdom Subscriber
    Kent UK
    Outstanding
  10. Digout
    Digout Australia Subscriber
    Excellent Work, Thanks for sharing the process.
    :thumbup: :thumbup:
  11. ColinG
    So... now I know it's possible this is definitely going to happen! I've found out that 34oz/8 cup cafetière has the same diameter as Vapalux/Bialaddin globes so that will be my first attempt.
  12. phaedrus42
    Update: I have changed my setup. Having the Dremel in a vertical position and the globe to be cut standing on end next to it seems to work much better. It prevents scoring marks from splinters scratching the sides of the globe as you rotate it. Using the laboratory glass stand to hold the dremel also makes it easier to adjust the height. Remember to wear eye protection and to continuously feed a dribble of water into the cut.
  13. WimVe
    Good job !
    Are you left handed, btw ?
  14. phaedrus42
    Wow, Wim, you've really got me scratching my head now, trying to figure out why I did it that way. :doh::-s No, I'm generally right handed but I can now see why you would think otherwise, looking at the photos. I gave it no thought at the time, but it seemed natural to me to rotate the glass with my left hand while feeding water with my right. Maybe I was subconsciously looking at it as if it were a metal working lathe, where one would control the left-right motion of the toolpost with the left hand and the in-out motion with the right.
  15. ColinG
    I have a Dremel copy but I don't think it'll be up to the job so now I'm looking for the real thing!
  16. JonD
    JonD Subscriber
    Hertfordshire, England
    Maybe save your money.
    The slop in my Dremel bearings is quite abysmal...
    I hate to say the 4 letter word that starts with J and ends with K
  17. phaedrus42
    I'm sure a dremel copy will work just fine as long as the cutting disc does not wobble. High speed and torque not needed; just take it slow and easy.
  18. ColinG
    I've ordered a diamond cutting disc and plan to use it in my pillar drill and off-set the base plate to one side to support the jug when I do the cutting. I think that should do the trick.
  19. Titoo
    Titoo France Subscriber
    FRANCE: 25 Franche Comté
    Hi Phil,
    Fantastic job :clap:
    Congratulation
    Regards,
    Titoo
  20. kenmack
    How about if you cut from the inside of the globe? Will this limit the spatter? Also, it seems easy enough to rig a continuous water drip from an elevated reservoir.
  21. phaedrus42
    That is a very good suggestion! I will certainly try it next time.:shock::doh::oops::D:clap:
  22. scl
    united states
    very steady hand there.
  23. A Hendrikx Netherlands
    Netherlands
    nice job!! do you not water to cool the glass or cuttingdisk?
  24. phaedrus42
    Yes, I dribble water into the cut from a squeeze bottle with a plastic tube.
  25. scl
    united states
    i have a 200a infrared that i need the outer glass for and found a straight side vase that is the right size. wondering if this method would work or if it is only good for the heat treated type of glass
  26. ColinG
    I guess you can use this technique on any glass, but if it's not borosilicate glass like Pyrex it'll most likely crack or shatter. I've found that cafetière inserts made of Pyrex are the perfect diameter for Bialaddin lanterns and others. I've cut down quite a few and the pouring spout is actually quite useful for lighting the pre-heater.
  27. A Hendrikx Netherlands
    Netherlands
    it also works with Jack Daniels bottels, cool the disk with water and dont rush.
  28. phaedrus42
    You can certainly cut it using this tehnique; just slow and easy with plenty of water on the cut. But whether it will withstand the heat on the lantern is another question.
  29. bp4willi
    yes phaedrus42, pls tell if cutted edge stands the heat of lit lantern without crack.
    regs
    willi
  30. ColinG
    If I had an oxy-acetalene torch and an old turntable I would attempt melting the top and bottom edges so they look professionally finished but I can't justify the cost!
