Evening Light Up
Discussion in 'Lamp Action Gallery' started by Johnny19, Apr 20, 2021.
  1. Johnny19
    Johnny19 United Kingdom Subscriber
    Liverpool
    I decided to give the AFC Ashflash an outing tonight, so here's a few shots!
  2. John
    John United States Subscriber
    Dallas, Texas; United States
    That’s making a very good light and it’s in very good condition also.
    That does the job.:thumbup:
  4. Johnny19
    Liverpool
    Its a nice lamp, but its a job to get it going.
    You have to turn the pump rod and get a sweet spot to build pressure. Then when first lit you have to drop a bit of pressure to avoid a flare up. That's even with the quarter turn of the valve. Only then can you crank it up and build pressure and she runs lovely.
  5. Tony Press
    These lanterns fire up much more cleanly if you fit a metho pre-heater, or use a metho torch to heat the generator first.
  6. Johnny19
    Liverpool
    @Tony Press Yes, I was thinking along those lines.... I reckon one of those cheap butane torches would do the job. :thumbup:
  7. Tony Press
    Don’t go that way - all you need is a Coleman-type priming cup or a long brass wire with a wick on the end that you use like a match.
