Finally fettled!
Discussion in 'Fettling Forum' started by JEFF JOHNSON, Sep 27, 2020.
  1. JEFF JOHNSON
    The first two images show some lanterns and an R-1 which have been in my shed for some considerable time and as there is nothing currently turning up, I finally got around to fettling them to working order.
    The second two images show a jar which is a fine size for Tilley meths torches, it will hold 3 of the modern torches or 2 of the older ones.
  2. podbros
    Wirral
    Hi Jeff!.. They look great!:thumbup:
    I am really liking the 2 older Tilleys though :)...The R1 has a lovely aged patina to it?
    I never thought about a bigger jar? It just makes so much sense when I'm fiddling around with a small thing always having to fill it up :doh:
    Vegemite jars are a good size for Tilley torches...
    Nice work on the fettles, Jeff.
  4. ROBBO55
    Jeff, they have all cleaned up nicely :thumbup:
  5. AussiePete
    They’re looking great Jeff.
    As Tony said, Vegemite jars work well, especially the earlier ones with the metal lid.
    Thanks for the positive comments fellow lampers!:thumbup::thumbup::thumbup::thumbup:
    The R-1 tank and the PL., tank both left the factory with a highly polished and lacquered finish and their current finish is what's left of the original finish.
    The R-1 is a pre 1940 tank, so it should have an XN., control cock fitted, but I don't have a spare one, so a GF., control cock will have to do and I still need to find a wire guard for the R-1.
  7. Henry Plews
    l like the early PL53 with the loose wire coil on the handle.
  8. JEFF JOHNSON
    Yes, it's a fine old timer.
  9. Sellig33
    Sellig33 France Subscriber
    @JEFF JOHNSON ,
    Dijon mustard, the best one !!!
    I'm born in Dijon :D/
  10. BigStevie
    Great line up Jeff. I too like that PL, very nice indeed!
  11. Fireexit1
    A fine row of tilley goodness..
    cheers
    Chris
  12. ColinG
    Before lockdown I went on a search for jars that would make good Tilley preheat tong containers and if my memory serves, Morrison's pesto jars were kind of close.
  13. JEFF JOHNSON
    Thanks one and all!:thumbup::thumbup::thumbup::thumbup:
    Sellig33 I have been in France a few times, but not for many years, so I cannot recall all of the places which I visited, but that mustard is good!:thumbup:
    ColinG Yes, Pesto jars are a good size for one Tilley meths torch.
  14. george
    If any of you fellows have new borns or baby grand children, empty baby food jars are really nice for alcohol bottles.
  15. JEFF JOHNSON
    I have now found an XN., control cock for the R-1, it was in my shed in a box of parts, but I still need to find a wire guard.
  16. Scotlamp
    Scotlamp United Kingdom Subscriber
    Kent UK
    Nice work Jeff nice selection Sorry about the DiJon puns But Colemans for me Yeeee Haaa
  17. JEFF JOHNSON
    Thanks and that's fair enough!:thumbup:
  18. Jean J
    I’m partial to Colman’s and Colemans myself!
  19. JEFF JOHNSON
    Very good Jean!:thumbup:
  20. JEFF JOHNSON
    The XN., control cock which I found is worn out, but it will do for parts, so I refitted the GF., control cock and here is an image of the 1930's R-1 lit.
    It's heat is very welcome on this cold night.:thumbup::thumbup:
  21. JEFF JOHNSON
    Here are three images of the 1930's PL-53 lit, the period burner which I fitted has seen a lot of use, so it's not as bright as it could be, hopefully a less used burner will turn up.
    Having said that, it's working okay for a lantern which is over 80 years old.
  22. george
    I like Coleman's, too, but I really go for the Tilley PL models! :thumbup:
    @Jean J
  23. JEFF JOHNSON
    Yes, those early PL., models are a favourite of mine too.
    george
  24. Tony Press
    @JEFF JOHNSON
    The bail on your PL 53 looks as though it’s been repaired. Did you do that, or was it like that when you got it?
  25. JEFF JOHNSON
    Well spotted Tony, it was broken when I obtained that lantern and my old mate Les fixed it, by simply drilling out a piece of brass rod on his lathe and then soldering the two broken ends of the handle into the tube.
    When I obtained that PL., it was incomplete, just the tank and handle and the pump, so it's built with what I had.
    Tony Press
  26. Mr cod
    Mr cod Subscriber
    Aylsham norfolk
    The pl53 has a certain charm which is very pleasing to the eye.
  27. JEFF JOHNSON
    I concur and they are usually simple to fettle.
  28. Cliff Ward
    Cliff Ward United States Subscriber
    Cary, North Carolina
    Nice lineup with those PL-53s....they have a very unique look!
  29. JEFF JOHNSON
    Yes, they are fine old lanterns and I have three 1930's examples, which all have differences in their design, I also have 1940's example and the link below shows the relevant gallery page.
    PL52-PL53-PL54
  30. Alex74
    Faringdon, Oxon
    Nice stuff Jeff! Where do you find your lanterns up in the Shetlands? Do you buy online or tend to find in shops?
