first attempt at soldering.....
Discussion in 'Fettling Forum' started by TocsinEd, Jan 30, 2019.
  1. TocsinEd
    Harder than I thought.
    I have a Bialaddin that had a a large leak, replacement washers in everything sorted it out but there was still a 'micro' leak - from around the control cock boss.
    Reading posts on here, and following advice from various forum members i bit the bullet and soldered it.
    It came out okay, i am quite pleased, will re-pressure test it tomorrow to see if it's cured the slight leak.
    Filled the font with water, and draped wet cloths over the filling and pump tubes so they didnt accidentally unsolder.....
    Luckily it all went okay, couple of aborted attempts but i cleaned it up again and 3rd time was the charm.
    This shows where it was leaking
    before prep
    After paint stripping
    flux applied, and black marker to stop the solder flowing too far out
    and soldered.
    As this was a new thing for me to try, i spoilt myself and opened my last new-old stock box of Ersin lead solder. I was saving this for a special occasion, cant think of a better one personally. Cost 75p decades ago lol, lovely solder this.
    Will pressure test, and test light tomorrow evening after works and report back.
    Thanks to all those that gave advice, much appreciated.
    Ed
  2. X246A
    Norfolk, England
    @TocsinEd
    Looks to have done the job. Hopefully the pressure test will confirm this.
    Regards Jeremy
  3. phaedrus42
    A neat job!
  4. MYN
    That's a really neat job done for a first attempt.
    If it cured the leak, you'd be on the same league as a soldering professional.
  5. Henry Plews
    Nicely done, it's certainly much neater than my first attempt.
    Henry.
  6. JonD
    JonD Subscriber
    Hertfordshire, England
    You had the good solder there with Ersin Multicore.
    All the same be proud of that lovely neat shiny fillet! Are you taking commissions? :clap:
  7. TocsinEd
    haha perhaps it wasnt a complete first time fluke, i have soldered electrical components for years and have been welding with both arc and MIG for years (and dabbled in TIG - but thats hard as hell) so i understand the technique - heat (apply lots but not to much), keep moving, don't add to little or to much filler metal!
    I am very pleased with how it came out, and i think i will deliberately start looking for leaky and broken things that i can solder up :)
    The erisn solder is amazing stuff, its really good, flows well and the flux in it is nice. Its my favourite solder. Shame i am on my last big reel (that should last a while though lol)
    Ed
  8. MYN
    That explains it, @TocsinEd .
    I was thinking that you must be naturally-gifted in soldering to be able to accomplish that on your first attempt.:).
  9. TocsinEd
    No leaks and the lamp doesn’t ‘pulse’ after about 10mins of running.
    Ran it for 30mins and outside was gone dry, will do a long run later to see if it does anything when it’s nice and warmed up
    Pretty pleased :)
    Ed
    E84FAEB3-3B96-4383-A5C7-ACC0C54A3013.jpeg DD672C33-4A5D-46F0-A91C-E9B5BECA08A3.jpeg
  10. X246A
    Norfolk, England
    @TocsinEd
    Another lantern resurrected to live again.
    Regards Jeremy
  11. TocsinEd
    Yep it’s a user not a shelf queen, it will be out next weekend being used :)
