Goldmohar 561 not pressurizing
Discussion in 'Fettling Forum' started by LanternTom, Sep 12, 2019.
  1. LanternTom
    Hebron, Indiana
    I started to fettle my, new to me , Goldmohar 561 and when i pump it is not taking any pressure. I pulled the nrv and it looks good. Any other ideas? I believe it is a Pmax 821 clone. What else should i try?
    If it has a leather pump washer, then you could soak it in oil for a while and then try it again.
    It's also a good idea to check the seals on the fuel cap/pressure gauge.
  3. Polybus Australia
    Sydney
    If it is not pressuring, then there are only really two possibilities:
    1. The pressure is not getting in, or
    2. The pressure is getting out
    1: Pressure is not getting in:
    Pump not working correctly - As Jeff says: Make sure your leather pump washer is good - soak in oil or replace.
    NRV not letting pressure in - but you say it looks good - and I suspect you would feel that when you pump
    2: The pressure is getting out:
    Leaks - Check/Replace your seals - Pump seals - Fuel Cap/Pressure gauge - the pressure gauge itself
    Perhaps the leak might be up in the control cock? Vapouriser?
    Holes in the fount(??!?!)
    Perhaps submerge in water and start pumping , see if you can see any tell tale bubbles.
    Polybus
  4. chopperjohn United States
    US
    I’m restoring an Adia. I too am having pressure problems. Got the check valve working but I want to replace all of the washers/seals. Where can I purchase parts in the US? Thanks Polybus!
  5. chopperjohn United States
    US
    My bad. I didn’t realize you are down under
  6. WimVe
    The AIDA is identical to the Petromax lantern.
    Look for a Px dealership or go to the internet via fleabay or another digital market.
  7. podbros
    Hi @chopperjohn and Welcome !
    good advice from Wim :thumbup:
    you should be able to get parts from
    Britelyt.com
    regards
    pb
  8. chopperjohn United States
    US
    Thanks for the reply. I’m new with trying to restore the Petromax/Adia lanterns. From past experience there always seems to be a new “distributor” of these lanterns and the quality was sometimes sketchy. I’ll try Britelyt. Thx
