I need parts for Petromax 900 Little Baby
Discussion in 'Pressure Lamp Discussion Forum' started by Cesar, Jul 15, 2019.
  1. Cesar
    Cesar Chile Subscriber
    Chile, Southamerica
    Hello everybody! I'm New in this wonder forum, it's my first post then thank you for allowing me to enter.
    I have some preassure Petromax lamps, the smallest need some parts, I appreciate your advice.
    A 28 number is writed un the bottom of thank, what does It mean?
    Parts that I need:
    -Glass cylinder
    -Hood with cap
    -Whole inner cleading
    -Spray nozzle
    -Needle
    -Pump plunger Plate
    -Leather collar
    -Pump plunger nut
    -Spring
  2. Cesar
    Chile, Southamerica
    Maybe the lamp could need other parts that are not visible, it's part of the things I need to know.
    Also I need some Mantles.
  3. ASHOK KUMAR
    ASHOK KUMAR India Subscriber
    India
    @Cesar
    Dear Cesar
    Welcome to the Forums
    Good that You have come to right place. Experts are here , they will certainly will help you. Experts @Mackburner @george @WimVe @MYN may help you - Regards
  4. JohanOptimus
    JohanOptimus South Africa Subscriber
    South Africa
    Good Day Cesar
    Welcome to the forum. I do not wish to discourage you, but perhaps I can save you some money and disappointment.
    I suspect spares for these older Petromax lamps in South America will be as scarce as anywhere else. After 6 months and a couple of hundred US Dollars you might be lucky to have found all the parts you need. Your time and money could be better spent on finding other lamps.
    My suggestion would be to keep the lantern for spares, or wait until you find another and perhaps build up a complete one. You might also use it as trade with fellow collectors.
  5. WimVe
    The 900 model is one of the specific lanterns of E&G which part are not exchangeable with now a day parts.
    And it is a rare model. Best change is to find another one for parts.
    Mind you its a 900HK and not 150cp model.
  6. ASHOK KUMAR
    India
    @Cesar
    What is Height of the lamp
  7. Erik Leger
    Erik Leger Germany Subscriber
    Wim, typo: 100HK
    Erik
  8. MYN
    I'm definitely not an expert, @ASHOK KUMAR
    That's way too flattering for me.
    Whatever comments that I've posted in the past, present or any indefinite extent into the future were and should only be treated as my personal opinions, which might or might not be agreed by others, much less even being drawn from well-documented facts.
    Welcome to the forum @Cesar
    The 100HK Petromax 900; Little Baby is a pretty rare lantern from E&G as mentioned before.
    Its quite unlikely you'll be able to find its original spare parts unless you are really lucky. I'd say, you take the advices as mentioned here by @JohanOptimus and @WimVe ...
    But the wait could take forever, and you might likely be anxious to make it functional.
    If that's the case, the only way is to fabricate some of the parts yourself. But you'll need the exact dimensions and geometries. Others here might be able to help on the dimensions.
    Except for the burner hood, J-tube mixing chamber and the outer hood, the missing rest are not exactly too difficult to make.
    You could easily source out a replacement glass globe or a mica one.
  9. JEFF JOHNSON
  10. ASHOK KUMAR
    India
    Thank you bro@MYN
  11. Cesar
    Chile, Southamerica
    I know it is difficult to find original parts and although it is my final goal while I would like to get the glass and other alternative parts to be able to light it.
    Here some measurements.
  12. AussiePete
    Welcome to this forum @Cesar
  13. MYN
    The following link provides some pictorial info of what the parts of the Petromax 900 would look like:
    Scroll through the pages to view the inner burner hood. Its different from the other larger Petromaxes.
    You might still be able to find parts for a 150HK lantern and convert it as such but I think they are a little different from the 100HK. Not exact fit.
    Its almost identical to an Aida 100.
    I do not have a Little Baby, else I'll provide some dimensional info.
  14. Tony Press
    Tony Press Antarctica Subscriber
    @Cesar
    Welcome, Cesar.
    If you do find a supply of parts, let me know. I need some as well!
    Saludos
  15. Kari Finland
    Finland
    Someone is selling Little Baby parts in a Finnish online fleemarket. I'm not sure is it ok to put the link here? The pic shows the set on sale for 40€.
  16. Carlsson
    If it's not a live bidding auction, but has a fixed price, it's OK to put up a link.
  17. Kari Finland
    Finland
    Well, here you go then. Little baby Petromax osat, Järvenpää
    You can contact the seller with the blue "Lähetä viesti" -button. Note that same seller also has Tilley parts for sale like shades and globes and a Tilley table lamp. I have been a little tempted for that my self :-k. Maybe she is willing to send abroad.
  18. george
    Is it possible that some parts from the new 150 cp Petromax 830 might fit the Petromax 900?:-k
    I think I might have the numbers wrong on this but someone will correct me.:mrgreen:
  19. Mackburner
    George. Sorry but no, 150cp parts will not fit the 900. Several of us have tried that and they don't. Finding parts for a 900 is so difficult because they are not compatible with any modern lantern. The inner hood is not like the 150cp and the jet nipple is too big. Also the 150cp pricker may be adaptable to fit the pricker rod of a 900 but the wire is too thick and would have to be ground down to fit. I don't know if that has been tried though. ::Neil::
  20. MYN
    The jet nipple orifice would be smaller than 0.15mm, possibly at about 0.12mm. The needle should be approx. 0.01mm smaller in diametre than the orifice.
    Does any have the thread size and dimensions of the jet? That might help in case the original couldn't be sourced out.
  21. Cesar
    Chile, Southamerica
    Now I have more conviction that it is very difficult to get original parts however this makes me more eager to continue looking, plus all the desire to help that I have felt in this forum surprises me a lot so I thank you. I think I'll start by buying a glass, because at least one of the hk150 (Petromax 830) can be used, do you have any recommendation about glass as close to the original?
    Any link?
  22. Mackburner
    Lahde gives the 100cp orifice as 0.12mm or 0.0047". ::Neil::
  23. Juan
    Chuta, weon!
    You are lucky I'm in Mendoza and I have "just" three of these for spares. Where are you from, in Chile?
    When you come to Mendoza we can chat a little and perhaps to make a deal. Do you have something to trade? Or perhaps some friend or relative.
    Don't ask me, please, to send it by post.
    I also have globes, I guess.
  24. Cesar
    Chile, Southamerica
    Bien Juan!!!
    For my luck in all parts of the world there is an Argentinean, Juan, thank you for your words and desire to help me, tell me if you have any part of what I'm looking for and maybe some pictures. We can also speak in Spanish by private message.
  25. Juan
    Ahhhh, no, this is an English spoken forum!!!
    I have to look, but I guess I have everything you need.
    The only problem is: I don't sell, just trade so you have something to offer (lamps, lanterns, etc); the other issue, as I mentioned before, is I hate Argentine post.
    Well, let's continue this by pm.
    Juan
  26. Juan
    Yes, I'm sure I have jet, pricker rod and needle, burner with nozzle, chimney and a local made (not original) glass globe.
    I can't understand what is missed on the pump.
  27. Juan
    What parts do you need, Tony?
  28. Tony Press
    Juan
    Vapouriser and jet; complete pricker rod (with bottom brass block that the eccentric shaft fits into) and pricker.
  29. MYN
    That's lucky you've got @Juan chiming in.
    Petromax had been in Argentina before, so I guess you might have better luck over there:content:
  30. Juan
    Let me see.
