June 1955 Coleman 249 Made in England
Discussion in '249, 249D, 249E' started by Andrew T, Feb 17, 2023.
  1. Andrew T
    Port Elizabeth South Africa
    It is very much the same as my other England 249. Difference is black Enamel inside the vent and a double triangle stamp on the valve body. The valve wheel looks to be threaded onto the valve shaft but also will not budge so I still don't know for sure.
    I came globeless and with a 241 nickel filler cap which I replaced with one which is also more rounded on the top edge same as my other one.
    The shim was removed from inside the burner. 20230217_180628.jpg 20230217_180642.jpg 20230217_180703.jpg 20230217_180650.jpg 20230217_153308.jpg 20230217_153208.jpg 20230217_152507.jpg 20230216_142506.jpg 20230216_141547.jpg 20230217_190526.jpg
  2. Jean J
    Nice, Andrew!
    Another fine example.:thumbup:
