Late model Bialaddin bowl fire (F2700)
Discussion in 'Bowl Fires & Heaters' started by presscall, May 22, 2020.
  1. presscall
    UK
    A well-used example, seals, pump cup washer and NRV ‘pip’ replaced, so functional and not pretty.
    No priming cup when I got the Bialaddin a couple of years ago so I made one, very loosely based on that on a Mk.I bowl fire, with a priming ‘spout’ (actually more of a chute) to conveniently channel priming alcohol into the cup.
    Brass sheet was from a badly stress-cracked fuel tank from a stove I canibalised for parts to make up a good example. Hard soldered (silbraze) construction to cope with the heat of priming.
    Before trimming and clean-up.
    Ready to install.
    The spike on the base engages with a hole in the reflector, orientating the filling spout to a point between the guard wires and preventing the cup from twisting round when filling.
    @David Shouksmith helpfully pointed out that though the priming cup with a spout equipped only the Mk.I bowl fire, the later models still had that locating hole in the reflector.
    Sure enough, there it is.
    Cup installed, spike/pip engaged.
    On the Mk.I, two guard wires straddle the vertical centre-line. On this later version a guard wire occupies that centre-line.
    Consequently, I’d to ensure the spout/chute was offset when the spike/pip was engaged with the locating hole in the reflector.
    Priming.
    Ignition.
    John
    Excellent! Great work on the priming cup, filler chute, and engaging spike.:thumbup::thumbup::thumbup:.
    I’ll have to see what’s on my unfettled Bialaddin bowlfire.
  3. plantpot United Kingdom
    London
    nice work on the cup, I always wondered what the hole in the reflector was for on my bowl fire.
  4. Keith Warby
    Keith Warby United Kingdom Subscriber
    Holbeach England
    Ahhhh now I see, mine must have a later heater. Thought it was a rogue reflector that escaped quality control when it came out of the factory.
  5. BigStevie
    @presscall Excellent job on the priming cup! Good to see the heater fired up. Been looking for a Bowlfire for a while to add to the collection....
  6. MikeO
    MikeO Subscriber
    Great looking heater. Love the design of the wire guard.
    And that's some mighty nice brass-smithing on the preheat cup!
    Mike.
  7. JEFF JOHNSON
    Well fettled!:thumbup:
