Latest tool acquisition - BA tap and die set
Discussion in 'Fettling Forum' started by ColinG, Jul 13, 2020.
  1. ColinG
    I've been wanting a BA set for some time and this was only £20 off eBay! Sizes are 10BA to 0BA, plus there were a few extra taps, BSW mainly. This should prove very useful!
  3. podbros
    Wirral
    That's good price for a good brand!..Looks like it has been looked after..:thumbup:
  4. Norman
    Spokane, WA
    Colin what a great score.
    You are going to find these tools very useful.
    Cheers,
    Norman
  5. MYN
    Nice acquisition.
  6. Tony Press
    @ColinG
    Are you sure you haven’t been sneaking into my shed...? I’d better go and check.;)
    That is a nice kit.
  7. ROBBO55
    Excellent Colin. You can never have to many tools. :lol:
  8. BigStevie
    Well found, good quality set at sensible money!
  9. ColinG
    Yup, it should be very useful as so many British lamps use BA sizes, Willis and Bates being just one.
  10. presscall
    UK
    Beautiful - the box as well as the taps and dies. Seller got screwed at £20.
  11. AussiePete
  12. Matti Kucer
    Matti Kucer Sweden Subscriber
    Sweden
    What set to search for if one want a set for the Swedish lanterns?
    I haven't got a clue what type they have.
    Any ideas what to search for?
    Regards Matti Kucer
  13. Nils Stephenson
    Swedish lamps use a combination of Whitworth and metric threads. When you think of Primus, they made their own. Usually metric diameter with Whitworth thread.
  14. Tony Press
    ...There’s something to mess with your mind!
  15. podbros
    Wirral
    @Nils Stephenson ..Do you mean a metric thread with a Whitworth profile?
    ...Or that the thread length corresponds to Whitworth T.P.I, but the diameter is a metric size?
  16. Nils Stephenson
    @Tony Press , @podbros
    An example is the Primus 1020 jet. the Thread has a 7mm diameter but it uses a 35tpi Whitworth thread profile. Primus was part of the huge Bahco company, so they could make whatever they liked. This way you had to buy genuine spares. A good idea at the time, but not for us now.
  17. MYN
    The problem is that a many of the concerned parts on most of the brands I've seen have non-standard dimensions on the threaded areas. Well the threaded pitches could be standard Whitworth, UNC, UNF/UNS or metric, etc but the diametres aren't. Which means that many couldn't be threaded with standard taps and dies.
    On such scenarios, I'd have them threaded on a lathe, which could produce the standard pitches on any diametres (outside threads). Threaded holes would be a little more challenging without the specific tap size.
  18. MYN
    I remember having some problems with the 35tpi Whitworth on a Primus jet, which is not a standard size.
    35tpi is not a standard unified thread pitch as well. It couldn't be produced on a general purpose lathe too.
  19. MikeO
    MikeO Subscriber
    Beautiful set. I remember using a tap and die set for the first time and how it revolutionized life in the shop.
    Pivotal moments in my life--learning to weld (still a hack), use a tap and die, use a sewing machine, fly cast without piling the line into the back of my head.
    Mike.
  20. ColinG
    I don't know which tools you'd need for Swedish lanterns but almost certainly metric.
  21. Matti Kucer
    Sweden
    Thanks all for the response. I'll search for a set for metric system.
    So much knowledge here.
  22. Nils Stephenson
    @Matti Kucer
    I have a metric set and a Whitworth set. That covers a lot of applications. For some reason Whitworth was very popular in Sweden in (at least) the first half of the 1900s.
    Just a few more examples. The screw for the top nut on Primus hoods is 3/16" W, the nut holding the cage base to the tank is 1/4" W and the grub screw for the cleaning wheel is 1/8" W.
