Making a globe retaining ring for a Wizard No55
Discussion in 'Fettling Forum' started by ROBBO55, Aug 21, 2025.
  1. ROBBO55
    I picked up a Wizard 55 hollow wire lamp at the last Staffordshire Reef gathering. Shown here Wizard N0.55 hollow wire lamp
    It’s in good condition but the globe retaining ring was missing. Making a replacement seemed simple enough but ended up being more time consuming than expected.
    @Anthony supplied me with some photos and enough measurements to give it a go.
    First, I need some detailed drawings
    Bending a 3/16” brass rod into a circle by hand didn’t work.
    I needed to make a bending tool capable of forming a circle
    I seem to have lost the photos from forming the finger grips from 1/8” brass rod but they were not too difficult. I used 2 x 7mm dia steel rods, held in as a former and held them in a vice.
    Drilled the mounting holes in the rod at 45 Deg and silver soldered them in place.
    When fitted the diameter was a little small and I had to cut and silver soldered in a piece.
    Success
    Nice work!
  3. pete sav
    pete sav Founder Member
    West yorks
    Nice job you made of it
    I like the bending tool as well good idea
    Well fettled!:thumbup:
  5. Sellig33
    Sellig33 France Subscriber
  6. ROBBO55
  7. podbros
    Good work :thumbup::thumbup:
    the former you mentioned for bending the finger grips could be known as ‘dogs’ over here.. certainly an old smithing term and i still use pairs of dogs for forming flats and round bars when needed :-)
  8. ROBBO55
    Thanks podbros
    This was one of those long drawnout projects, where you start, have a problem and set it aside whilst you ponder on a solution. In this case a lot of pondering.:-k
  9. Paul Aslanides
    Ferntree Gully, Melbourne.
    @ROBBO55
    Well done, top job.
    Cheers.
  10. Paul Aslanides
    @podbros
    Could you possibly post a photo or two of your various " dogs " and how to use them ? I need to learn. Thanks.
  11. Camp numao Japan
    Japan
    This is professional processing technology!
    It's so satisfying to look at.
