Making Primus 1020 cleaning needles
Discussion in 'Fettling Forum' started by Nils Stephenson, Jan 6, 2019.
  1. Nils Stephenson
    It has been mentioned a few times in different threads, so I thought I might as well try and describe how I make my own cleaning needles for the Primus 1020 (and all the other models with this burner).
    To start with I use two different sizes of brass tubing. The reason I use two tubes is that I don't have the skills or facilities to drill a small hole in a 2mm rod. I use 1mm outside diameter with a 0.4mm hole and 2mm outside dimater with a 1mm hole. I have purchased them from an online model/hobby shop and they were relatively inexpensive. I also use stainless steel acupuncture needles in 0.18mm diameter, again bought online.
    Here is a picture of some of the items I use.
    First off I cut 7mm lengths of the two tubes using a dremel with a cutting disc.
    I then put the 1mm tube inside the 2mm tube, put in the acupuncture needle, then crimp half the length of the tubing to fix the needle.
    Next up I hold the tubing in a drill chuck then cut a #2 UNF thread on the non crimped half.
    Finally I cut off the needle at 2.5mm and it's good to go.
    A bit fiddly, but the result works and I have the satisfaction of knowing I did it myself. :)
  2. phaedrus42
    A very good technique, Nils! I will certainly try it out some time. K&S Hobby Metals make the correct diameters of brass tubing. I have used it to make cleaning needles for various Coleman lanterns. On the Coleman cleaning needles, the crimping is the hardest part to get right, I've found.
  3. Nils Stephenson
    Yes, sometimes I have to straighten the crimped part before cutting the thread.
    Ideally for the Primus needles it should be 2.1mm, but I havn't found this size anywhere.
    I have also used the same idea for Austramax cleaning needles. They're not very common here in Denmark. :)
    Great fettling!:thumbup::clap::D/:D/:clap::thumbup:
  5. MarkC
    MarkC Subscriber
    Tallinn
    Thanks Nils. Great stuff
  6. Martin K.
    Martin K. Subscriber
    I found that the needle rod contained in the 24x Coleman Generators also is a thin brass tube. I've already used that one to make needles for my Ditmar lanterns in a very similar way. However, I've currently no measurements (inner/outer diameter) at hand.
  7. Tony Press
    Tony Press Antarctica Subscriber
    Thanks, Nils.
    I’ve got a Gloria that I need to do this with.
    What’s that crimping tool brand?
    I’ve used an electrician’s crimping tool, but it’s a bit narrow and the crimp a bit severe, so I’ve gone to using the edge of a flat piece of steel and a peen hammer.
  8. ROBBO55
    Excellent technique Nils :thumbup:
  9. Martin K.
  10. Tony Press
    Thank you, Martin.
  11. Nils Stephenson
    The crimping tool is not perfect, but it is the best I have at the moment. It tends to crimp a bit lopsided, so I try to turn the tube and crimp a second time from the other side. The best solution would be something that has an even pressure from several directions at once. I thought I found one at work that would be ideal with six jaws, but the jaws were spring loaded and didn't have the strength to crimp the brass tube.
  12. tretrop
    tretrop Sweden Subscriber
    Sweden
    One of the highend crimptools , this one does a 8-indent crimp would be your best tool for this. Price is around 100-300 USD
    [​IMG]
    crimptool
  13. MarkC
    MarkC Subscriber
    Tallinn
    Here is a Chinese knock-off on ali-express
  14. Nils Stephenson
    These are the type of crimping tool I tried, but the jaws were not strong enough to crimp the rather thick brass tube. I expect the ones shown would also have a problem. It would be good if we could find some that do work. I'd buy some. :)
  15. MYN
    I have one of those 4 sided ones that crimps into a square profile instead of hexagonal. They are meant for wire ferrules/pins and won't be strong enough if the brass tubes or copper cable links that are too thick. I have yet to find any hydraulically actuated types which are that small.
    No harm buying those Chinese knockoffs to try out as they are relatively inexpensive.
    Branded ones such as Knipex, Lappkabel, etc would cost much more.
    I've been inspired by @Nils Stephenson to make my own Primus cleaning needle. Unfortunately, I couldn't any acupuncture needles to make the crimped type.
  16. Jan-Ove Lorentzen
    Jan-Ove Lorentzen Norway Subscriber
    Norge
