Optimus 1300 (early)
Discussion in '1300' started by stejar, Jan 3, 2011.
  1. stejar
    An early Optimus 1300, still with just ”Optimus 300” engraved on the tank.
    Stefan
    Apparently Optimus had already intended to use the designation “1300” to this “300” with preheater. Oddly enough the tank is only engraved “300” and not “1300”, but the original box and the spares kit that goes with this lantern are both stamped “1300”. Therefore I think it’s fair to assume that the 1300 designation was intended all along, but for some reason it was not actually engraved on the lanterns on the early production runs. The same phenomena can also be observed on early 200/1200 lanterns. (It’s not unknown for Optimus to only have the full designation on the cardboard box.)
    On the tank you can see the early “angular” lettering “Optimus” (the same as on Optimus 00 Patent stoves) and the likewise early oval Optimus globe. The top is black enamel fastened with two screws. Among the spares, notice the thin cleaning needle that I think is for the pre heater. The spare jet is marked “300” in an oval, but “Optimus” in not stamped on it.
    1294061484-Optimus_1300_2_opt.jpg 1294061511-Optimus_1300_3_opt.jpg 1294061536-Optimus_1300_4_opt.jpg 1294061559-Optimus_1300_5_opt.jpg 1294061587-Optimus_1300_6_opt.jpg 1294061607-Optimus_1300_7_opt.jpg 1294061628-Optimus_1300_8_opt.jpg 1294061645-Optimus_1300_9_opt.jpg 1294061663-Optimus_1300_10_opt.jpg
  2. Nils Stephenson
    Nice one Stefan. Very nice to see an example with box and parts.
    I've often wondered why sometimes you see these lanterns with only 300 on the tank. It's not like it is the same tank as the 300, as there is the quick starter fitting.
  3. stejar
    You are right Nils, they must have had had different tool made for this tank and not just the same as the 300. Why not engrave it “1300” in that case?
    Stefan
