Optimus 200 Harp
Discussion in 'Indoor Lamps' started by karli, Feb 7, 2011.
  1. karli
    karli Subscriber
  2. Nils Stephenson
    Is it a standard Optimus 200 lantern you have here? This hanging frame and shade were normally sold together with the 265 lamp, which would make it a model 268. The 265 is not very common at all. This type of frame is often seen together with a 255 lamp, but is not shown in any catalogue that way.
  3. karli
    karli Subscriber
    This is a regular 200, this shade doesn't fit to
    the 255, so I took this 200hk lantern
  4. Nils Stephenson
    I'll have to get back to you on this one. I was under the impression that there was only one type of shade for these hanging frames. I don't have a shade myself, but I have heard that it is a "challenge" to get the 255 and shade into the frame. I think you fit the shade first then insert the lamp. You only need three or four hands to do it. :lol:
  5. Carlsson
    Karli, you accidentally placed this lamp under HASAG, so I moved it to Optimus for you.
    Whether it actually should be under indoor lamps is another question, which I hope you will solve here.
    We can do the move to the correct place later.
  6. karli
    karli Subscriber
    Thank you.
    Sorry for this mistake
    At the moment I have Hasag fever :roll:
  7. Nils Stephenson
    Now I have checked a couple of catalogues and the shade for the 258 and the 268 should be the same. At least they have the same part number (122K).
