Optimus 252
Discussion in 'Indoor Lamps' started by James, May 28, 2015.
  1. James
    James Subscriber
    I assume this is a rather battered Optimus 252.
    Got a bit of work to do on this one. Air release screw has broken off in the cap. Vapourizer has been repaired but obviously not completely :shock:
  2. Nils Stephenson
    Even though it looks a bit tired, that was a nice find. It looks to be an early one too.
    The vaporiser will have to be repaired as they are a bit longer than the standard 200 item. The globe is going to be the tricky bit.
    A good find! :thumbup:
  4. Claus C
    Gratz James. Battered or not. It is there, it works and that is what counts. :thumbup:
    Claus C
  5. James
    James Subscriber
    The leak in the vapourizer didn't show up during a dunk test, only when the lamp was running. Turns out it was a small crack which must open up when the brass is hot.
    I brazed the crack up and gave the lamp a good clean and it is running well :thumbup:
    There's an eBay seller in Korea selling the glass (reproduction?) but it's rather expensive so I think I will do without for the time being.
    Great fettling! :thumbup: :D/ :clap: :D/ :clap: :thumbup:
  7. ROBBO55
    Great work, looks good. :thumbup: :clap: :thumbup:
  8. Nils Stephenson
    Quite a bit of difference there. A big improvement.
    I've had one of these vaporisers with a crack as well. Mine was in the preston loop facing the mantle. Also an early variant. Maybe they had a bad batch of raw material at one point.
  9. James
    James Subscriber
    Can I get a replacement air release screw for it? If so I might try to get the broken stub out.
