Optimus 300P Lantern
Discussion in '300' started by Norman, Apr 1, 2020.
  1. Norman
    Spokane, WA
    Hello folks,
    I've acquired an Optimus 300P. The lantern was in pieces and in need of quite a bit of cleaning. The fount has quite a few dents but I found no leaks when pressurized but found some leaks when the found was depressurized so I used a two part epoxy which took care of the problem.
    All seals and washers were replaced. The fuel leveling gauge works quite well indeed.
    The jet/nipple and pricker needed to be replaced.
    I decided to use an Egret mantle rated between 300 C.P - 400 C.P. This mantle is very bright.
    Here are some pictures and yes it does need some more cleaning that's for sure.
    DSC09843.JPG DSC09844.JPG DSC09845.JPG DSC09846.JPG DSC09847.JPG DSC09848.JPG DSC09849.JPG
    Here are the money shots.
    Cheers,
    Norman
  2. ColinG
    Nice! I have a 350p with a red hat and very handsome they are too!
  3. James K
    James K Subscriber
    The optimus lamps are very well made and do fettle up quite well.
    It's nice to see it shining bright again.
    Good work.
  4. AussiePete
    @Norman
    Nice looking lamp and she runs well, well done mate on a good job. I reckon she looks good as she is, kind of “been around” sort of lady.
    She sure chucks the light out with the mantle your using.
  5. Mr cod
    Mr cod Subscriber
    Aylsham norfolk
    Working very well ,nice and bright . Have you any indication of age of this lamp.
    Regards Ian.
  6. Alex Smith
    Central, UK
    @Norman Good looking lantern there, looks like you have done quite a bit of work on it already - well fettled.
  7. Norman
    Spokane, WA
    Thank you all for you very kind comments.
    This lantern may be from the late 1950s but I'm not sure.
    Cheers,
    Norman
  8. JEFF JOHNSON
    Well saved!:thumbup:
  9. Nils Stephenson
    This lantern is actually from the late 1940s. It is a bit of a crossover version from the last version of the 300. Optimus were still using up their stock of the red wheel and nickel top cap before going over to the brown wheel and red enamelled top cap. I believe everything else is correct for the first variation of the 300P.
  10. Norman
    Spokane, WA
    Thanks Jeff.
    Thank you Nils for the information on this lantern.
    I had no idea this lantern was from the late 1940s.
    Cheers,
    Norman
