Penetrating Oil What's Best?
Discussion in 'Fettling Forum' started by plantpot, Aug 10, 2019.
  1. plantpot
    plantpot United States Subscriber
    London
    Hi all
    One of the chaps on here kindly mentioned home brew penetrating oil, a mix of 50/50 ATF or light cooking oil and acetone.
    Well I tried that and found that using light cooking oil, sunflower, mixed with acetone does not mix but the acetone floats on the top of the oil.
    tried it with 3 in One oil and the same (I don't have ATF (Auto Trans Fluid I am guessing) It does not mix.
    So I can't for the life of me think this could work as it seperates, like oil and water. (perhaps good on a salad????)
    I am using 99.9 % acetone.
    Any suggestions please? If not what do you use as good penetrating oil?
  2. JohanOptimus
    JohanOptimus South Africa Subscriber
    South Africa
    ATF and acetone definately works.
  3. cmb56
    cmb56 Sweden Subscriber
    Norrköping, Sweden
    @plantpot
    Why do you think that Automatic Transmission Fluid and Cooking Oil would be the same?
    Do you not have any car part dealer or gas station near you where you can buy a bottle of ATF.
    In any case, there are many different penetrating oils to buy if go for that, 5-56, Rocol to name some.
    WD-40 is NOT such!
    Michael
  4. AussiePete
    I can definitely confirm that a mixture of 50% acetone and 50% ATF (Automatic Transmission Fluid) works exceptionally well, and is cheap in comparison. Yes it will seperate when on the shelf, but give it a good shake just before using it. There is no doubt in my mind that this is the best penetrating fluid that I have ever used.
  5. plantpot
    London
    Thanks folks, I'll try to get some ATF and give it a shot, I was just a bit worried it would not work because of the separation.
  6. Tony Press
    @plantpot
    Ensure that you shake your ATF/acetone mix before use. As said above, it works very well.
    I also have a commercial penetrating oil - brand name “Penetrene” that works very well.
