Petromax 797 steel tank and without pump
Discussion in 'Hanging lamps' started by Kawpan, May 3, 2020.
  1. Kawpan Thailand
    Sai-yok
    Tony Press New Zealand Subscriber
    @Kawpan
    You certainly have some very fine hanging lamps!
  3. Mackburner
    Nice old one as well. 797 is basically a model 836 800cp lamp but without a pump. It only appears in catalogues from 1926 to 1930 so is likely to be not very common. ::Neil::
  4. Matty
    Queensland, Australia
    No pump means it is gravity or you use an external pump?
  5. Henry Plews
    @Matty
    External pump. The filler cap is adapted to take the connector of a bicycle pump.
    A very lucky find!:thumbup:
  7. Kawpan Thailand
    Sai-yok
    Thank you for everybody
  8. WimVe
    These where designed to use with a fuel line and fuel tank with pump.
    Racek sold them in India.
