Petromax 829 flickering light
Discussion in 'Pressure Lamp Discussion Forum' started by Cesar, Sep 22, 2019.
  1. Cesar
    Cesar Chile Subscriber
    Chile, Southamerica
    Hi everybody! My lantern have some faint flicker from the moment it turns on.
    The frecuency is like 2 Herz.
    Is it a characteristic of the lamp or something is wrong?
  2. Seamanjive
    Seamanjive Subscriber
    London, England
    Hi Cesaer...do you have full tank of fuel and sufficient pressure?
  3. Cesar
    Chile, Southamerica
  4. Seamanjive
    London, England
    When my Optimus 1550G had a problem with pulsing after reassembled the vaporiser. I eventually noticed that the needle was protruding more through the jet than it did before it took it apart. I lowered the needle and the pulsing is now gone. It returns if the pressure falls or the fuel level is low. The pulsing also seems to make the tank warm as vaporized fuel moves up and down the column.
    I was only able to solve these problems by following the excellent advice given by the good people on this forum. I take no credit for discovering these solutions myself. The level of experience here is so high and wide.
    Hope this might help you as it has helped me.
    Rgds
    Jamie
  5. bp4willi
    @Cesar
    You need to add a spiral of stranded copper wire in the tube of vaporiser below the Preston loop.
    This helps for more even, continuous vaporisation. Avoids the Leidenfrost effect of pulsing.
  6. Seamanjive
    London, England
    I'm intrigued by this solution. Does the brass gauze/copper wire go inside the vaporiser tube? How do you get it in there and get the needle through? Anyone got any pictures?
  7. bp4willi
    @Seamanjive
    I regret. Have no pics.
    But is simple.
    Remove jet, needle and upper part of vaporiser.
    Wind stranded wire around the shaft of a screwdriver with appropriate dimension.
    Outer diameter of spiral should match inner diameter of vaporiser tube.
    Spiral should stretch from Preston loop down to the hand wheel, within the vaporiser.
    Push the spiral gently in the tube.
    Put all together again.
    Enjoy flicker free light.
  8. Seamanjive
    London, England
    Thanks for clear explanation. I think I have solved the problem but will experiment with your method.
    Rgds
    James
  9. Cesar
    Chile, Southamerica
    I think in the 50s, you go to a Petromax or another brand technical service, You carry your lamp with a flickering ... what would have been the "official" solution of the company? and I also wonder, our lamps when they were new, did they have flickering problems?
  10. george
    All pressure lanterns flicker to some extent, even the best of them. It's normal and most of the time your brain can't pick it up. However, when it does then you have a slight problem.
    Good advice here. Try it and see what happens.
  11. ColinG
    I have used the copper wire trick with most of my Petromax clones and it definitely works. My 829 also has a flicker and I'll be using copper wire to cure that too.
    Don't forget to make sure all the other adjustments are set correctly love the fuel air mix and the internal vane that's operated by the grub screw on the J tube. Once all that's done and the wire is in place my guess is it should run nicely without any pulsing.
    To be honest I use a slightly different technique with the wire... I wind it round the pricker rod and then reassemble the vaporiser. It seems to work just as well as far as I can tell it you need to be careful not to damage the pricker wire! I sometimes unscrews it before I start work.
  12. Seamanjive
    London, England
    That makes sense, wind control rod before inserting it. How close/tight are the windings? And copper or brass? Would copper become molten at the temperatures inside the generator?
  13. Graham P
    Graham P Australia Subscriber
    Albury area NSW AUstralia
    I wonder if the specification of current kerosene is the same as it was in days gone and that is contributing to problems, classic cars do not run well on modern pump petrol ??
  14. ColinG
    I found there wasn't much choice in the tightness of the winding but so long as it's there it seems to work. I believe it simply increases the surface area to heat the kero.
  15. Mackburner
    Brass will always be better than copper in a generator. Copper oxidises to black flaky crap under heat although a generator probably doesn't get hot enough. I would not wind wire around the pricker rod either. Better to roll some brass mesh around it. Mind you the difference is probably minimal and either will work fine. ::Neil::
  16. Seamanjive
    London, England
    I think I'll give it a go...although I seemed to have currently cured the pulsing with needle/jet/airgap adjustment.
    My current prob is with the 1550 is that the pump leather disintegrated and is in bits at the bottom of the pump chamber. Think I need a dental probe to dig it out. Also, I dont think a Tilley leather is the right size. Mmmmmm..
  17. Mackburner
    ::Neil::
  18. bp4willi
    @Mackburner
    You share a lot of amazing competence and convincing thought.
    But this time
    I can't agree.
    Copper won't oxidise to flaky black soot ...within the vaporiser ...... Because
    Within the vaporiser is during operation
    Only kero and kero gas
    No oxygen.
    Oxidization will certainly happen. But not in excess.
    Black surface is rather kero coal . similar to cracking process which bursts Tilley vaporisers
    And to avoid flickering, copper has advantage over brass
    Due to better heat conduction in copper than in brass.
    And yes, both, copper and brass stuffing work more effective
    If it touches vaporiser tube from inside. For good heat conduction.
  19. Mackburner
    OK that makes sense. I stand corrected. ::Neil::
  20. WimVe
    Strange that nobody mentions the mix paddle.
    normally the lanterns don't flicker.
  21. ColinG
    I've messed around with the mix paddle but it's minimal in it's effectiveness, at least that's what I found. It does something, just not much.
  22. george
    It will cut down on brightness, at least that's what mine does. It's somewhat minimal but it works. It doesn't have any affect on flickering.
  23. WimVe
    The flcikering is caused by the "Leidenfrost effect".
    But this was known I guess by the designers.
    I think that the shape of the mantle, the quality of the fuel and maybe not very clean parts will stimulate this effect.
    The mixing paddle is the last object in the gas stream and should be used to make a adjustment to the gasflow by means of reflected light.
    You adjust the brightness, that is optimun gas flow, by looking at the reflected light from a (white) piece of paper.
