Petromax No:90 lead washer - dimensions
Discussion in 'Fettling Forum' started by spiritburner, Feb 11, 2018.
  1. spiritburner
    spiritburner United Kingdom Admin Subscriber
    N.E. England
    Hi - does anyone have the dimensions of this lead washer please?
    Regards
  2. Nils Stephenson
    Nils Stephenson Denmark Founder Member
    If they're anything like the Optimus part, they are OD: 16mm and ID 10mm.
  3. spiritburner
    N.E. England
  4. Nils Stephenson
    I don't have any originals left but the lead I use to make my own washers is 1.5mm thick. I usually use two washers at a time which is maybe a bit too much so maybe 2mm would be the right size.
  5. phaedrus42
    phaedrus42 South Africa Subscriber
    Somerset West, near Cape Town, South Africa
    On the Butterfly Brand washers I have seen the cross section was square, i.e. the thickness was the same as the difference between ID and OD. Do you plan on casting them or punching them out, Ross? I suppose casting them would be the most economical use of material, if you have a mold made for you.
  6. WimVe
    WimVe Netherlands Subscriber
    Holland
    I have: 14 on 10 and 2mm thick.
  7. spiritburner
    N.E. England
    Thanks everyone. They will be punched - or more accurately, pressed.
  8. Asbestos
    Asbestos United States Subscriber
    Washhington State, USA
    I can't imagine casting them. I need a new one and I am going to take some roofing lead (from around a vent) and use a metal roller to get it to about the rights thickness then use a large hole punch for the OD and a smaller one for the hole size. I am thinking that the thickness should not be to crucial as long as it is close, it's lead and should smash down a bit.
  9. george
    Mt. Airy, USA
    They are available all over eBay, why try to make them? :?
  10. JonD
    JonD Sweden Subscriber
    Hertfordshire, England
    For the satisfaction of it maybe - I would!
    Casting them I don't think I would try - not much success with that so far - apart from making lumps - akin to fishing weights.
    Punching from roofers lead sounds like fun, even trepanning them out.
    Watching with interest.
  11. Nils Stephenson
    Roofing lead is what I've been using for years. With a set of concentric punches it makes it easy. The stuff I have is about 1.5mm thick so usually use two washers together. Has worked every time for me. :)
  12. phaedrus42
    I've made quite a few from sheet lead with hollow punches. I've also used solid lead wire formed into a circle and the ends soldered together. Works just as well. What did not work well and started leaking after a while was to form a ring from resin core solder, also with the ends soldered together. Still not quite sure why that was...
  13. phaedrus42
    Depending on the hardness and thickness of the lead you use it is a good idea to put copaslip on the screw threads when you tighten it up. There is quite a lot of torque and strain to the brass and this way the energy is transmitted to the lead and not to overcome friction in the brass screw threads.
  14. JonD
    Good try Phil, the trouble with cored solder is you have only part of the volume. It looks like lead - but maybe about 40% by volume is rosin cores.
    What do you have left over after the magic smoke departed?
  15. CPLS
    CPLS South Africa Subscriber
    South Africa
    Using rolled roofing lead and a punch will work for sure. Simplicity always wins.
  16. Asbestos
    copaslip. Had to google that one.
  17. phaedrus42
    Google is your friend and Bob's your uncle! :lol:
