Petromax preheater pointing straight up (no offset).
Discussion in 'Pressure Lamp Discussion Forum' started by Reinhard, Jun 9, 2019.
  1. Reinhard Germany
    Admin edit: The following discussion was split out of this topic.
    @WimVe
    Maybe the Rapid is a bit open.
    But the knob looks a little different.
    Regards Reinhard
  2. WimVe
    What do you mean by open ?
    On lanterns the rapid always points towards the coil.
  3. Reinhard Germany
    @WimVe
    Picture 1 closed
    Picture 2 open
  4. WimVe
    Yes ok, but what relation is there with the straight or angle towards the preston coil ?
    So to be more precise the angle of the rapid in relation with the tank top.
  5. Reinhard Germany
    @WimVe
    With the Petromax 827 with rotary quick preheated, the hole for the rapid is offset a little bit inwards.
    Seen in this light, the angle of the rapid preheated should be right.
  6. MYN
    I see what you meant @Reinhard .
    We've been mostly accustomed to the angled mountings of such rapid preheaters. I'm not aware that there had actually been some that were designed to point vertically upwards.
  7. Tony Press
    Sorry about the slight diversion, but the topic of where the Rapid Heater was pointing on my 1937 No. 827 came up earlier in this thread.
    Assuming that the Preston loop is meant to be positioned in the centre of the lantern (not offset left or right), the Rapid Heater would point vertically to the high side of of the Preston loop at approximately 9 o’clock.
    The gold and silver dot shows where the jet points to the Preston loop.
    @Reinhard @WimVe
  8. WimVe
    @Tony Press,
    Thanks for the pictures.
    Well the idea was to pre heat the vaporizer so "normally" the rapid point towards the six o'clock point.
    That is where the two ends of the coil meet the vaporizer.
  9. MYN
    Your pictures are very clear, @Tony Press .
    Now that's quite new to me, (I mean the offset mount and the vertical direction of the preheater).
    If it could perform the preheat function nicely, then it fits its purpose. No matter if its pointing at an angle or vertical.
  10. Reinhard Germany
    @MYN
    Can you please show the hood and the inner coat?
    @Tony Press and @WimVe
    Maybe they were experimenting with the inclination angle of the rapid preheater. It was the first rapid.
    My two lamps do not look much better.
    Regards Reinhard
  11. WimVe
    Reinhard,
    I strongly advice you to buy and read the Lahde book. There is also a patent of the rapid types:
    DE636752 1935 -1936
    Even the first ones are place under an angle.
    [​IMG]
    Just an idea: if you want to solder, with an open flame, where do you point the flame at ?
    My idea: the lantern got a kick on the rapid and was bend.
  12. Reinhard Germany
    @WimVe
    I have looked at exactly these and similar drawings before. And yet I wrote what I wrote. I also have two such lamps as Tony. But they have not get a kick and they do not look much better.
    Paperwork and reality sometimes go far apart.
    I strongly advise you not always to hide behind your documents.
  13. WimVe
    Well @Reinhard I don't hide behind documents.
  14. george
    The Lahde book is one hellva great reference! I have a copy thanks to Wim and there is a whole ton of really good info. The math is migraine reading at best but you put that aside.
    Highly recommend!:thumbup::D
  15. Tony Press
    Wim and/or Reinhard
    Can you post a photograph of the place where the control block of the rapid heater sits on the tank on one of these early 827 lanterns.
    Here is what mine looks like. If the jet was pointing at the 6 O’clock, the tank would have a different shape at that point, and the control handle would point up toward the hood (not horizontally).
    Best regards
    @WimVe @Reinhard
  16. Nils Stephenson
    I have no experience with Petromax lamps, but the Swedish models have the rapid assembly aligned so the tube is pointing towards the larger section of the vapouriser (as mentioned by Wim). To accomplish this the mounting hole is not level with the top of the tank. Maybe the top of your tank has been bent at some stage? I would also expect the control wheel to be aligned at right angles to the centre line of the tank, not as it is now.
  17. Tony Press
    It seems to me that both the rapid heater control block and the generator control block are not at right angles to the centre of the tank. This lantern has obviously had a hard life and been worked on.
    I'll search for paperwork on this model.
    @Nils Stephenson
  18. MYN
    @Tony Press ,
    The only lantern I've came across which has a rapid preheater nearly as vertical as your unit is @Trojandog 's Aladdin-Petromax(1937...1939?):-
    I can't exactly see clearly (only appeared to me) but you could ask @Trojandog if that's the case.
  19. Kari Finland
    Finland
    Hello, first post here!
    At the moment I am fettling a Petromax 827 what I believe is from 1938. The rapid heater alignment looks like this...
  20. MYN
    Just another lookup back on @phaedrus42 's post back in Dec 8, 2016, I found some similarities between this and what's on his lantern:
    Its either not very common or I was just not observant enough to notice this variation.
  21. george
    I have an 828 from around 1936, and quite frankly I have never noticed any difference between my 1936 828 and my 1960s 828. They both appear to be aimed at the "heart" of the Preston ring....:-k
    Could the Rapid lighter have taken a whack at one time that caused it to change the angle?:whistle:
  22. george
    Thinking about it, Wim has something: where do you point the flame if you want to solder something? You wouldn't point it "away" from the object.:-k
  23. WimVe
    I herewith present to you, pictures made by George of his Petromax 828 (around 1936) :
  24. WimVe
    If I compare the pictures of George with those of Tony I think I see deformation, on the outside pushed down and on the inside material is pushed up:
  25. Tony Press
    Wim
    Yes. There is indeed the appearance of deformation in my tank, consistent with the fitting having been moved, at the point where you have directed your yellow arrows. There are also ‘post factory’ additional lead washers as well.
    It will take me a while to work on this lantern, but I’ll get it going eventually.
    @WimVe
  26. AussiePete
    This is what I love about our forum, people all over the world with knowledge and expertise that will resolve the issues, in this case the angle of the preheater. Fascinating to read and looks like you’re getting to the bottom of it.
  27. Tony Press
