Pionier 4615 S
Discussion in 'Continental' started by Erik Leger, Dec 19, 2010.
  1. Erik Leger
    Erik Leger Germany Subscriber
    3000 HK kerosene searchlight (300 HK burner, 3000 HK reflected, later re-rated to 4000 HK by the company for advertising purposes) in carrying case with spare parts.
  2. Markus Hirt Germany
    Deutschland Bayern
    Hallo Erik,
    ich habe genau so eine Lampe auf dem Speicher gefunden. Gibt es irgendwo eine Anleitung dazu, bevor ich einfach versuche!
    Danke für deine Antwort!
    sG
    Markus
    Hello Erik,
    I found exactly that lamp in the store. Is there any guidance on this before I just try!
    Thanks for your Ant
  4. Wim
    Wim Subscriber
    Dendermonde, Belgium
  5. AussiePete
    AussiePete Sweden Subscriber
    We all need Ants ...... what’s a picnic without them :lol:
  6. Tony Press
    Ant?
  7. leo
    leo Germany Subscriber
    No Ants ;) answer/reply :)
  8. Erik Leger
    Thanks for the ping, Wim.
    No, no detailed instruction sheet in my papers for that one. (got eaten by ants??)
    But you find a lot of details on my website.
    btw. These lanterns mainly run on gasoline which is a little more flammable than kerosene. I assume you know what you are doing. The pump valve is a spring loaded check valve only so make sure it seals properly. The lantern will have a positive fuel shut-off valve which may need some service, too.
    (If your lantern has no fuel valve it is to be run on kero.)
    Erik
  9. AussiePete
    Bloody ants .........:rage:
