Pork pie... to paint or not paint.
Discussion in 'Fettling Forum' started by Paul Burnell, Oct 28, 2024.
  1. Paul Burnell
    Paul Burnell Malta Subscriber
    Ireland
    Hi Guys
    Got this awhile back WhatsApp Image 2024-10-28 at 12.37.55.jpeg and its been just sitting on the shelf. Decided its time to lazarus-ize it.
    Took a wire wheel to it and underneath all the crud was this beautiful patina.
    So the questions are... Do I prime and paint it in its original colour or lacquer it as is.
    To be honest I'm liking the aged look.
    And what causes this copper effect. I thought these were made out of pure brass.
  2. podbros
    Hi @Paul Burnell
    Brass isn’t a base metal, it’s an alloy of Copper and Zinc.. have a look online for the many types of brasses out there.. :thumbup:
    I think folks have talked about the varying quality of the brass found in the (tilley) lamps/lanterns around this time.. very common to see multiple flecks of differing colours in with the brass when stripped of paint
    I remember that some members have also had issues with perforations with some of the pork pie types so I would recommend a good pressure test before any form of finish?
    Maybe start with a ‘dunk test’ ?
    hope that helps,
    regards
    pb
  3. Fireexit1 United Kingdom
    The copper on the surface may be a result of an acid that has removed the zinc from the brass leaving the copper behind. I have used plastikote paint directly on fonts with good results.
    Coming along !
    :thumbup:
  4. Paul Burnell
    Ireland
    Great information there @podbros I'm ashamed to say that I didn't know copper was an ingredient of brass. It makes total sense now.
    I will definitely do a complete dunk test, normally I just use a spray bottle and fairy liquid, but this seems to merit the full monty.
  5. Paul Burnell
    Ireland
    @Fireexit1 Thanks, I just googled plastikote and it looks like great stuff.....
    I tend to go for the Halfords brand paint, its reasonably priced and easy to source...
    Since this is my first and only pork pie I may just try it.
