pre 1920 Nulite 110 M lamp
Discussion in 'Nulite- National Stamping and Electric Co' started by Conny C, Nov 18, 2015.
  1. Conny C
    Conny C Sweden Subscriber
    Hi all,
    This is one of my two examples of the Nulite 110 M lamp. The 100 M lamp was a development of the torch lighting 110 lamp into a match lighting lamp. The first match lighting generator for this lamp model was a coiled generator, very much like the Q99, but with a conical connector. My lamp has the coiled match lighting generator and a burner supported by a steel rod. Shallow fount with a angled straight air tube.
    I'm not sure is this is the first or second version of the Nulite 110M. In a catalogue pre 1920 of Neil Mc Rae, there is a 110M lamp with a higher fount and a burner with the coiled match lighting generator, supported by an air tube (very much like the Akron 102 ).
    Later in the 20,s there was a third version of the 110 M lamp, now with a flat square burner supporting section, curved air tube and now also with a new generator, the "umbrella" inverted cup generator. A patent for that lamp was filed in first of November 1920, patent granted June 3rd 1924 (which is stamped on the inverted cup of the generator).
    My lamp came in a used condition, a bit poor plating and a battered coiled generator. Cleaned up nicely though and with the original pretzel shade it is on of the nicest looking table lamps in my opinion.
    /Conny
    1447882955-Nulite_110M_lamp.jpg 1447882984-Nulite_110_M__lit_mantles.jpg 1447882997-Nulite_110_M__lit.jpg 1447883009-Nulite_110_M__Bunsen_flames.jpg 1447883024-Nulite_110_M_parts.jpg 1447883040-Nulite_110_M_side_view.jpg 1447883067-Nulite_110_M__generators.jpg
    1920/1924 patent drawing 1447883171-1920_-1924_patent.jpg 1919? catalogue drawing from the Nulite 76 catalogue (owned and shared by Neil McRae) 1447883246-Nulite_110_M_catalogue_76.jpg
    comparison of my two 110M lamps 1447883330-Nulite_110_M__two_versions1.jpg 1447883349-Nulite_110_M__two_version_2.jpg
    and some "before shots". 1447883389-Nulite_110_M__Before_3.jpg 1447883405-Nulite_110_M__Before_2.jpg 1447883421-Nulite_110_M__Before_1.jpg
  2. Jean J
    Conny, you lucky devil I have been hunting around for a shade for the lamp I posted here on 1 November. Probably never find one but I can dream!
