Primus 1010 heater
Discussion in 'Lamp Action Gallery' started by Darryl Durdin, Apr 19, 2021.
  1. Darryl Durdin
    Just putting may latest fettle to the test
  2. Jean J
    Looks cosy Darryl.
  3. Andrew T
    Port Elizabeth South Africa
    Looks good
  4. Jacques Van Der Rijst South Africa
    Pretoria, South Africa
    That looks very nice!
  5. Tony Press
    You might have a loose nipple or an enlarged jet, Darryl.
  6. Walkop Australia
    I would like one of those for a campsite. Saves lugging a bulky gas cylinder around.
  7. Fireexit1
    Great looking example - but as Tony Press says - looks like it is not quite burning as the radiant heater gods intended...
  8. Carlsson
    Yes, and that part is also discussed here.
    It's a bit unfortunate when the same issue is spread in several topics.
    Regardless that, this heater is absolutely not running as it was supposed to, but luckily it will not be a thing that will be hard to solve.
    These burners are actually quite straightforward, so anyone who really intend to do so can make them run as intended.
  9. rayw
    The heater may have problems too
