Repairing Bialaddin bowl fire burners with exhaust paste
Discussion in 'Fettling Forum' started by MG, Nov 10, 2019.
  1. MG
    MG United Kingdom Subscriber
    hampshire UK
    As above, i'm talking about resealing the two halves/threaded pieces where the burners can leak from when the threads have burnt away, i have read about it but i'm just wondering how successful it has been for anyone that has tried it, i had a go at one last night but it set in the wrong position and i think i repaired one a while back which seemed to work ok iirc, i may have a couple more that i need to do but if it doesn't often work then i won't bother,
    I might also try some copper grease,
    Thanks.
    @MG
    If the threads are really pitted, you should try muffler paste. I happen to have a fair few spare Tilley burners that were assembled by another collector using muffler paste.
    If worse comes to worst you could clean it up and silbraze it together.
  3. MG
    hampshire UK
    @Tony Press
    Thanks Tony, i have got some GunGum, fibreglass reinforced exhaust/muffler paste so i will have another try, one burner has been put back together by what looks like a punch, the brass upper part has been punched onto the base but can still twist it a few mm's and hence leaks i presume and a couple of the others look like they have been doctored, i will take them apart so that i can try and seal them up properly, i don't want to throw them away if they can be saved as even secondhand they can be relatively expensive to replace.
    If they have been badly damaged, I would silbraze them.
  5. MG
    hampshire UK
    @Tony Press
    Sadly that is not in my repertoire Tony.
  6. Tony Press
    Then try the muffler paste.
  7. MG
    hampshire UK
    I've got a blow torch although i'm not sure how hot a piece would need to be for silver solder if that's the same as brazing? if i can't get the burners apart how clean has the joint got to be for the solder/brazing to take as i'm not sure how clean i could get the insides?
  8. Tony Press
    Before you go down this path, remember that once done it can’t be undone...
    You’ll need to get the brass very red hot. I use a MAPP torch. I gather some people use propane, but it’s a bit slower to get to the correct temperature.
    Cleanliness is everything in this game so I would clean with citric acid, then with steel wool or similar. I would use a sharp file to make a clean surface at each join.
    Look at the instructions for silver soldering (silbrazing; hard soldering) here:
    SMEX - Silver Soldering
  9. MG
    hampshire UK
    That's great, thanks Tony, i'll leave that as a last resort then and see how i get on with taking the burners apart first in case i can make that work.
  10. MG
    hampshire UK
    Well i took them all apart, cleaned them although none were dirty, none of the upper parts showed any wear or distortion, reassembled the ones with the tight threads with copper grease and the others with exhaust paste, tried the best three and not really any difference to speak of,
  11. george
    Two on the left in picture look like they're shot. Three on right look pretty good.
    :-k
  12. MG
    hampshire UK
    And the top one on the left works as well as the others, i haven't tried the one bottom left, i will rig them up on a working lantern tank and control cock and if that doesn't work then i'm stumped.
  13. Tony Press
    @MG
    Is your fuel ok?
    Do you smell kerosene fumes while it’s burning?
    If you are using aircraft-grade kerosene and all is well you should get no smell.
  14. AussiePete
    Bloody hell ... the 2 on the left have done a bit of work.
  15. MG
    hampshire UK
    @Tony Press
    Yes fuel is fine, i only use Paraffin Extra now, there is a smell but i put that down to the heater running rich with the symptom being the halo around the mantle.
    @AussiePete
    And i dressed up the bottom one as it was in even worse condition beforehand.
  16. Tony Press
    @MG
    Try mixing 15% naphtha: 90% paraffin in your heater.
    Naphtha = Coleman Fuel.
  17. MG
    hampshire UK
    @Tony Press
    Thanks Tony, that would be fine if i was keeping it but not sure the new owner would be ok using that mix, i haven't had any problems with the Paraffin Extra before and it burns much nicer than the Barrettine Paraffin that i previously used (which was fine in other bowl fires, maybe i should try some in this one) the nos vapouriser works fine in a lantern so i wonder why all three burners aren't working correctly in this instance?
  18. Tony Press
    Perplexing...
  19. MG
    hampshire UK
    That is one word to describe it Tony :lol:
  20. Tony Press
    @MG
    I’m sure you’ve thought of other unprintable expressions...
  21. MYN
    The bottom left one looks challenging. Might worth a try building that up with the exhaust/muffler paste and re-perforating it accordingly.
  22. MG
    hampshire UK
    @Tony Press
    Many my friend! and it gets worse the harder i try to fix the issue, i don't know enough to work out things like air/fuel ratios or whatever else might be causing the problem but you would think it can't be something that difficult, these are usually a robust heater.
  23. jacov
    jacov Subscriber
    @MG Just a thought, could it be that the mesh mantle is not allowing enough air into the interior thereof to allow a complete burn?
    I experienced this a while ago when trying to make a mesh mantle, only after I made two holes, approx 4 millimeters in diameter, did it burn well
    Thanks
    Jaco
  24. george
    Hummm..:-k
  25. MG
    hampshire UK
    @MYN
    I'm not sure i'll bother with that one as it is so far gone,
    @jacov
    Was that on a Tilley heater? i think i remember reading that thread,
    I have tried three different, genuine Bialaddin mantles so i don't think all three would be unserviceable but going by the burners who knows!
  26. MYN
    I'd guess you have enough spares to bother about the one at the bottom left of the picture.
    I've mended similarly shot burners with muffler paste, and they could perform surprising well after that. So if you could ever fix the worst one of the lot, the others should not pose any serious issues.
  27. MG
    hampshire UK
    You did well to be able to mend one in that condition Myn, it didn't even enter my mind that it was repairable,
    I wish i could figure out what the problem is considering the fairly decent condition of the other three.
  28. MYN
    Do not use copper slip/antiseize if the threads are too badly burnt and not securing well enough. The heated parts would expand, loosen and the attachment might just drop out.
    Either muffler paste or silbraze.
  29. JonD
    JonD Subscriber
    Hertfordshire, England
    Is the common part here the mixing chamber dome and air tube? If the fuel is right (vapouriser and tank) and it runs rich, surely it lacks air.
  30. MG
    hampshire UK
    @MYN
    Yes i only used copper grease on the tight threads all others exhaust paste,
    @JonD
    From what i can see, there is no wear to the mixing chambers/domes, i cleaned them by heating and quenching although they weren't that coked up and i made sure the air tubes etc were clear by using a pipe cleaner.
