Standard 2412
Discussion in 'Fettling Forum' started by Martin K., Nov 13, 2021.
  1. Martin K.
    Martin K. Subscriber
    Found this one in poor condition, but except of the mica cylinder it is now restored, thanks to a parts donor that I had in the cellar for a long time.
    I decided not to re-paint the tank green because of the decals. Instead I just used Owatrol Marine Oil to conserve it, after removing most of the rust. The old fuel residues could be removed well with dishwasher cleaner with some pipe cleaner added, which also helped to preserve the patina, instead of using citric acid.
    Surprisingly, underneath all the rust on the side of the tank, there was still some paint preserved, which I found out when I went after the rust with a small stainless steel brush on the Dremel.
    468_370401754.jpg 468_539155850.jpg 468_1624499703.jpg IMG_20211113_105547_a.jpg IMG_20211113_105521_a.jpg IMG_20211113_105509_a.jpg IMG_20211113_105532_a.jpg
  2. ROBBO55
    It cleaned up nicely, Martin. :thumbup:
  3. bp4willi
    Well preserved.
    The tanks is a bit too shiny. Wipe off some surplus oil??
  4. Martin K.
    The oil has already dried up and forms a kind of transparent varnish / lacquer. The overall impression is not so bad, but the lighting when I took the photos somehow seems to enhance the shine on the tank.
    Well saved.:thumbup:
