Tilley AL8 & AL9 Like Stand
Discussion in 'Fettling Forum' started by Sedgman, Oct 23, 2019.
  1. Sedgman
    I have admired the Tilley AL8 and AL9 trackwork lamps and to date no success, but I will keep trying. In the meantime I ran up my prototype of the 'robust frame' that they stand upon. I fabricated the rivets and snuck a small amount of weld in a few places but mainly it is rivets holding it together. I got a couple of minor things wrong in copying from pictures but reckon my next one may well be harder to pick from an original.
    Iain
    The rivets were made from small bolts.
    The screw that holds the lantern on.
    I shortcutted the narrower cross member which usually goes under the main central bar because it's usually out-of-sight. I learnt from this and the next will go under as per original.
  2. WimVe
    Nice job !
    As a railroad man I too like all the lantern variations that where made for railroad work.
    Strange enough I don't know of German made lanterns that where specific designed for railroad work. Petromax had the long bail with wooden handle as a railroad version but that is it.
    That is a robust looking stand!:thumbup::clap::clap::thumbup:
    It's possible to use a Tilley R-1 tank and pump and control cock and a 169 vapouriser and a plated reflector, if you have a CH-1 hood or an EX hood then either of those will do the job, but if not, then a modified X-246-B cage and a modified X-246-B hood will do and the link below shows that idea.
    https://classicpressurelamps.com/threads/vikingson-reflector-lamp.13922/
  4. Sedgman
  5. ROBBO55
    Looks good Iain and you have done a neat job of the riveting. :thumbup:
  6. AussiePete
    Nice work Iain. It looks very good and robust to boot. Well done.
