Tilley/Bia/Vap pricker wire tip re-point
Discussion in 'Fettling Forum' started by presscall, Jun 25, 2021.
  1. presscall
    Lancashire, UK
    Not an original method, but worth demonstrating.
    Magnified pricker wire tips. Top one is from a Tilley CS56 stove.
    I use one of these (fine grit diamond) in a Dremel (or equivalent).
    Tool is upright and direction of rotation is away from the wire point. Practice on a piece of wire before attempting the Tilley/Bialaddin/Vapalux re-pointing. The smallest amount of material should be removed.
    It shouldn’t shorten the pricker wire to the extent of compromising the pricking function, but I have on occasion extended the other end with a blob of silbraze, machined to blend in with the brass sleeve. A less elegant alternative would be to place a disc shim piece on the control cock cam.
    John
  2. Pancholoco1911 United States
    Great idea but are you shortening your pricker wire spring at the bottom?
  3. presscall
    Lancashire, UK
    Do you mean in a rare example where I’ve extended the length (fractionally) of the brass sleeve?
    In that case, no, but the extent if ‘shortening’ if any involved is a millimetre typically. The rare case might get to 2mm, when extending the length of the sleeve might be necessary. Even the 2mm wouldn’t/hasn’t led to a noticeably stiffer pricker action.
  4. Pancholoco1911 United States
    Never mind. Missed the part where says “stove” though it was for lamps
    sorry sir
