Tilley BR49 fettling
Discussion in 'Fettling Forum' started by Michel, Feb 16, 2020.
  1. Michel
    Michel Subscriber
    56 France
    Hi all
    this my next fettling project
    I am surprised : absolutely no stamping on the fount
    no Tilley, no letter, no number !!??
    The preheating system make me some troubles :
    the fuel don't climb in the preheating cup.
    The perheating system is dismantled
    Where could I find an exploded of this part in order to understand
    the way the fuel is directed towards the cup ?
  2. BigStevie
    Michel
    That lantern tank would be approximately 1949/1950 to 1954/5. It would be unstamped but may have had a Tilley transfer (decal).
    @Michel
  5. Michel
    Michel Subscriber
    56 France
    OK I found the patent
    Espacenet - Bibliographic data
    And I saw the very small hole in the bottom of the part
    now the problem is to unblock the conduit
    thank you all for the informations
  6. Michel
    Michel Subscriber
    56 France
    I had to change all the seals and after a good clean, here it is.
    I was afraid the kerosene gives me a yellow and smoky flame but not at all
    the preheater is very effective, I obtains a beautifull blue flame
  7. JEFF JOHNSON
    That's good news!:thumbup:
  8. AussiePete
    It’s ready to rock and roll with a mantle. These preheaters do the job very well.
    Well done on clearing the blockage and getting it to operate.
  9. Michel
    Michel Subscriber
    56 France
    Hi all
    the old lady in in order.
    But I have a problem : the lamp ran for 2 hours.
    Over time, the light went down and down and now the burner is deep red. I'm not an expert on the Tilleys, but I don't think that's normal.
    I had noted a halo around the mantle. I think this generator is a bit enlarged
    what explanation would you have?
  10. JEFF JOHNSON
    The most likely cause of that problem is that the jet in the vapouriser has become enlarged, but if there is a strong smell of paraffin, then part of the burner may have loosened.
  11. podbros
    Wirral
    Great pics and well done on all your hard work!:thumbup:
    Sounds like it's burning on the inside? Did you strip the burner down at all? They can wear and it's not always apparent where the problem is, hence the availability of repair kits with spare tubes etc.. sometimes the main burner body threads become so worn that it's hard for everything to seal properly?:-k
    The good news is there are lots of 2nd hand or even nos parts still available!
    Good luck with everything,
    Best wishes,
    pb
  12. Michel
    Michel Subscriber
    56 France
    yes guys, it seems it's burning in the inside even thought the burner have been dismantled and cleaned
    I did'nt notice a great smell of paraffine
    As I own another burner, I shall try tomorrow :-k
    I shall also be in need of a better hood :lol:
  13. george
    Do you think the lantern could be leaking air somewhere? An overlooked stress crack?
  14. Tony Press
    It’s best not to disassemble an old Tilley burner.
    With heavy use the threads tend to erode, so I always clean the burner and make sure it’s got no wasp or spider debris in it.
    If the burner is taken apart, I always put it back together with high temperature nickel grease.
    I have a few used burners in good condition where the previous owner has re-assembled them using muffler paste for the mixing tube thread.
    Another possibility for underburn inside the mixing tube is that the burner has been re-assembled with a long injector tube inside a short(er) mixing tube.
  15. Michel
    Michel Subscriber
    56 France
    it seems that you are right, guys,
    it is not a good idea to dismantle these old burners
    I changed the burner and the vaporizer, It is not new but healthy.
    the lamp has trouble rising to its proper operating temperature. I had a halo around the mantle for a long time, but it is stable now
    even though not very bright
  16. george
    Correct, DO NOT DISASSEMBLE THE BURNER!! They are a bitch to put back together - if you can even get them back together! Threads are usually shot to hell and burned.
    :rage:
  17. Michel
    Michel Subscriber
    56 France
    We learn something every day, even at my age:D/
  18. Michel
    Michel Subscriber
    56 France
    Hi all
    another question :doh:
    the patent for the preheating system on those BR49 have been claimed in 1930/31
    The first BR tilley lamps are dated 1949
    I wonder why the patent have not been in use before ?
  19. Mackburner
    It was used well before the BR lanterns. That pre heater is shown on model PL55 in a 1935 catalogue but it was in general use by the Rail companies on a range of lamps throughout the 1930s and 1940s. BR as British Rail didn't exist before 1948 when the rail companies were nationalised. That pre heater was probably designed for Great Western Rail but would have been used by all 4 rail companies in the 1930s. ::Neil::
    ::Neil::
  20. Michel
    Michel Subscriber
    56 France
    I suspected a little ;)
    thank you for the informations Neil
