Tilley FL6 Floor Stand
Discussion in 'Tilley' started by Tony Press, Oct 24, 2020.
  1. Tony Press
    This is a bog standard floor stand for a Tilley FL6, except for the fact that it is stamped with an ID number of some sort. I received this stand along with my SL1.
    KH94-6
  2. R100
    This is identical to the stand I have with my FL5. I wonder if the same stand was used for both models although I know the later FL6 versions were tubular. By the way, your SL1 is superb.
  3. WimVe
    I do see a difference in the way the mounting sleeve opening is made.
  4. R100
    Now you mention it there is a difference. The FL5 stand is counterbored at the fork to allow the pinned brass collar on the wingbolts to locate.
  5. Sedgman
    Wimmera, Victoria
    The stamping on the small FL6 stands are interesting. Mine is similar to the stamping Tony has shown above.
  6. Tony Press
    @Sedgman
    That is very interesting. What do you make the stamping out to read? And, does your stand have the recessed hole for the wing nut?
    @R100
    The stand that came with my 1937 FL6 has the counterbored holes:
  7. podbros
    Wirral
    Hum... They went to a fair bit of trouble to make that detail... Probably brazed as well as riveted then bored out.
    You could be sure that when you lifted it that the stand wasn't going to fall off :thumbup:
  8. Sedgman
    Wimmera, Victoria
    @Tony Press
    My stand has no recessed parts and the ends with the holes are just a steep angle welded or brazed very smoothly together. The lettering is confirmed as K H L 7 97
    Regards
  9. Tony Press
    Thanks, Iain.
  10. Sedgman
    Wimmera, Victoria
    Thought I'd add a photo of my FL6 small stand, seeing mine has holes and not a slot. Thus why, when I was building a tripod, I assumed they had holes.
  11. Tony Press
    Iain
    Is that the same stand as the one with the number stamped on it? Also, can you remember where, and with what attached, did you get that stamped floor stand.
    Mine came from South Australia.
    @Sedgman
  12. Sedgman
    Wimmera, Victoria
    @Tony Press
    Yes, same one. From a shop in Melb. The FL6 is the smaller pump 1936-37.
  13. R100
    Given the weight of these lamps I reckon aligning the holes with the mating holes on the lamp must be fun:content:
  14. Sedgman
    Wimmera, Victoria
    @R100
    Sort of. The small stand, is not too bad as you can stand over it and the ones with trunnion (slots) are easier. The one with holes is a tad awkward but OK. The tall tripod stands are OK with slots but the lanterns have a tendency to lean and you can get them slightly off if not careful. I had made a tall tripod and had just holes and that was a nightmare until I cut slots for it.
