Tilley FL6
Discussion in 'FL6 Floodlight Projector' started by R100, Nov 21, 2020.
  1. R100
    This is my newly restored Tilley FL6 which came from the collection of a late member. It has never been fired and the mantle is the original fitted in the factory back in March 1964. Restoration consisted of replacing all the seals and a complete re-paint to correct the damage caused by years in a damp garage. The original reflector is useable but I acquired a NOS replacement which is almost mint. I also had to restore the fuel gauge as per my "how to" here Restoration of Tilley fuel gauges for FL5, FL6 etc.)
    I do have the transfers for the back of the hood but I am struugling to find the silver Tilley transfer for the fount. If you know of anywhere I could obtain one, please let me know. (arty_pharty has none).
  2. BigStevie
    That’s looking very sharp, well fettled!
    A splendid example!:thumbup:
  4. Mr cod
    Mr cod Subscriber
    Aylsham norfolk
    Will this get fired for money shot
  5. R100
    It's Trevor's birthday light up tomorrow. Wait and see.;)
  6. Hanzo
    Hanzo Subscriber
    First class restore , even the screws are flawless.
  7. Alex Smith
    Central, UK
    That is absolutely gleaming, wow.... amazing.
  8. R100
    Thanks for the positive comments.
  9. MYN
    You don't get any better than that. Absolutely stunning.
  10. Fireexit1
    A proper restoration. Well done @R100
  11. Fireexit1
    If all else fails you can buy waterslide paper/film for use in an inkjet printer. You will have to varnish over it after application I guess.
  12. R100
    I would be happy to print my own if I had a pattern to follow. Ideally I would like to borrow a loose transfer which I can the photograph and print. I could get away with photographing a transfer already applied to the tank as I have full Photoshop facilities. No danger of that during lockdown.
  13. Gary Waller
    Gary Waller Subscriber
    @R100 lamps looks stunning. What silver / grey paint have you used.
  14. R100
  15. rayw
    That is a stunner, you have set quite a standard there.
  16. Fireexit1
    Yes I am going to have to change my avatar :oops:
  17. R100
    I finally got round to applying the transfers.
  18. Fireexit1
    The icing on a splendid cake !
  19. MYN
    Its so neat and looks like its just out from the factory at Hendon.
  20. BigStevie
    Superb result!
