Tilley Lamp indentification Please!
Discussion in 'Pressure Lamp Discussion Forum' started by John Craig, Oct 22, 2020.
  1. John Craig United Kingdom
    West Kilbride
    Hi all, I am refurbishing this old lantern. Just about to take it apart, replace seals and give her a clean and grease. I'm not sure exactly which model it is, and date of origin. Hoping if one of you could help please, I can then order an appropriate glass! 20201019_195638.jpg 20201019_195648.jpg 20201019_195653.jpg 20201019_195706.jpg
  2. David Shouksmith
    Judging by the clip handle attachment, that's a mid-late '50s Tilley X246 Guardsman - but usually at this point, someone else comes along and points out my dating error. They can also tell you about the hood which I think is one of the earlier ones without a flared upper rim.
    I think it probably needs a Tilley 171 'deep-dish' globe but these are getting rare (and more expensive). A later 171 will fit and work OK but they don't look quite right IMHO.
    Meanwhile, welcome to the forums and here's a little music while we're waiting for Neil or Tony Press to add their two penn'orth:-
  3. BigStevie
    Hi and welcome from the Highlands! Your Guardsman is a good strong old lamp and should come back to life easily. Have a look on YouTube for ‘broadlanders’ (aka Jeremy on this site) videos, they’ll give you a good step by step insight in what to do.
    As David mentioned, a later 171 globe will do the job fine.
    Happy fettling, Stevie
  5. Mackburner
    That is model X246 Guardsman from Oct 1957 to late 1961. It should have a date stamp in the base plate. "Strong" is not how I would describe these. This is the first tank that Tilley made with an inverted base plate and whilst they are perhaps better than the X246B tank are still more prone to dish down and tear the solder seam than earlier tanks. ::Neil::
  6. John Craig United Kingdom
    West Kilbride
    Wow! Thank you for the quick, informative, and friendly replies! I'l go order a glass now! Looking forward to breathing some life into this old beastie. There is no pressure build up on pumping. I am hoping once all the seals are installed that will change tho?
  7. Anthony
    Anthony Australia Subscriber
    @John Craig, I'll just wait to see if it does have a date stamp underneath :whistle:
  8. ROBBO55
    Welcome to CPL @John Craig . It should clean up nicely :thumbup:
  9. AussiePete
    @John Craig
    Welcome from Queensland Australia.
    It looks like you have been covered by the previous respondents.
    Just adding, check that the burner’s air tubes are clear of insect detritus and stuff. Spiders and wasps seems to like the air cavities for their domiciles.
    Further when you have the mantle installed and seals replaced, give her a good preheat before lighting.
    After you have this beastie running..... you need to get another lantern to keep this one company. I have found that these lanterns need to be in a crowd of lanterns, it makes them happier and as such they perform better .... :D/
    Enjoy
  10. Buggerlugs
    Very nice that should scrub up well, great find
  11. John Craig United Kingdom
    West Kilbride
    Hi Anthony, you are correct, no date stamp, just 'Made inEngland'.
  12. John Craig United Kingdom
    West Kilbride
    Thank you for all the warm welcomes and replies. And to AussiePete, haha, indeed! I have a Northstar, and about to get a 2nd. But I do like the idea of these older characterful lanterns. Combined with the world of enthusiasts I have discovered, it may well be yet another lovely distraction from the sometimes not so nice world at the moment!
  13. Anthony
    1954 to Sept,1956 then.
  14. John Craig United Kingdom
    West Kilbride
    Hi all, just been finally trying to fire the lamp up. I suspect the base is losing pressure. The mantle is only partially flaring, and the pump is not really showing any pressure pushing back. Can any of you give me some input please? I've replaced all the seals, and everything looked ok. The base has some dents, suspecting I need a new base? Best regards :-)
  15. JEFF JOHNSON
    Is the pump leather in good condition and is it well oiled, how long are you preheating the lantern for, they are meant to be preheated indoors.
  16. Ian Bingham
    Ian Bingham Subscriber
    Kent, England
    Does the pump travel without any real effort? If so, the pump cup leather is likely to need attention. If it is present and not fallen apart, try soaking in oil (any oil will do) and then spreading it a little.
  17. John Craig United Kingdom
    West Kilbride
    Pump travels quite easily. It's a new leather cup, I worked oil into it, but I will revisit and saturate. Thanks!
  18. John Craig United Kingdom
    West Kilbride
    I was pre-heating outside, but I'll try inside. It was maybe too cold and breezy! Thank you!
  19. Jean J
    AussiePete is trying to encourage you to get more lamps John but, believe me, you won’t need it. It just somehow happens to most of us.
  20. Henry Plews
    Except linseed. NEVER use linseed oil. Raw or boiled, the leather will go as hard as rock.
  21. george United States
    Yes, linseed oil will play hell with the leather pump. @Henry Plews Henry's 100 % correct on that! Been there, done that![-X
  22. Alex74
    Faringdon, Oxon
    I have just found two identical ones thanks to BigStevie who alerted me of a Gumtree sale near me. The enamelled tops have essentially rusted away. I’ll post a photo shortly.
  23. Alex74
    Faringdon, Oxon
  24. Alex Smith
    Central, UK
  25. Alex74
    Faringdon, Oxon
    They haven’t been fettled yet, so don’t count!!! :whistle:[-(
  26. Alex Smith
    Central, UK
    :lol::lol::lol::lol::lol:
