Tilley mantle spigots
Discussion in 'Fettling Forum' started by R100, Nov 15, 2020.
  1. R100
    I need to replace the spigot on my Tilley table lamp. Are they the same type as Tilley lantern spigots?
    Yes, they are the same.
    @R100
  3. R100
    Thanks Tony.
  4. Rangie
    Rangie Subscriber
    Have a quick measure to check they are the same length, you may find an odd longer "500" spigot in the spares pile. Otherwise they are the same.
    Standard - 28mm to shoulder, 500 - 48mm to shoulder (nominally).
    Alec.
  5. R100
    Thanks for that Alec. I am intending to order from Julian so I should be safe.
  6. Fireexit1
    It is included in Tilley SP3 - not sure if the internal steel burner tube and the dome is of any value ?
