Tilley R1
Discussion in 'Other Tilley Pressure Product' started by BigStevie, Aug 6, 2020.
  1. BigStevie
    Found this today in a local barn.
  2. paul m
    paul m Subscriber
    lancashire. UK
    Shame it doesn't have it's original control cock, you'd have struck gold then Stevie
  3. Jean J
    What’s wrong with that one Paul?
  4. paul m
    paul m Subscriber
    lancashire. UK
    Thought it would have the early brass one with that reflector, maybe wrong
  5. Tony Press
    @paul m
    Are you talking XN vs GF control cocks?
  6. Norman
    Spokane, WA
    Great find Stevie.
  7. JEFF JOHNSON
    A fine fettling project!:thumbup:
  8. BigStevie
    Thanks for all your comments folks. What age do we think? The fount is lacquered brass and the reflector has the oval Tilley badge as you can see in the first photo.
    It’s a bit rough and there’s a split in the reflector, on the plus side it’s totally unfaffed with.
    I’d like to know which is the correct control cock, any advice would be most welcome!
  9. Tony Press
    @BigStevie
    If that is the correct burner, you have got the correct control cock. If it were the longer control cock, the hole into which it screws would be much deeper than needed for the GF control cock:
    8 Tilley control cocks
  10. BigStevie
    @Tony Press
    Thanks for the information. I’ll have a good look at it over the weekend. I think I might have a GN cock somewhere..
  11. Tony Press
    @BigStevie
    A “GN” control cock would be most unusual.
  12. ColinG
    Nice find, Stevie!
  13. JEFF JOHNSON
    That tank will restore well and Tilley bowl fires were fitted with the 169 vapouriser, in my opinion, a previous owner has replaced the original control cock and burner and vapouriser with what was available at the time.
    The base plate of the tank may be painted black.
  14. BigStevie
    Haha, quite right! That’ll be a XN control cock!
  15. BigStevie
    @JEFF JOHNSON
    You’re on the money Jeff, the base is painted black and I too think it’s been maintained with available parts.
  16. podbros
    Wirral
    Great stuff Stevie :thumbup:
    Very common for them to split in that area.... :/
    I have seen something similar somewhere to that lower knurled nut on the reflector?...:-k
  17. BigStevie
    @podbros
    Similar to the knurled nuts on table lamp gallery springs?
  18. podbros
    Wirral
    ...More like a smaller version of the one that holds a wooden handle on something or other??...I dont know.. :/
  19. Sedgman
    I think you have done well obtaining it and with the woven mantle, though it may well need replacing. I like the round spherical wire replacement ones from England. The guard is also there which is a bonus as they are often missing. Good luck with it.
  20. Jacky Young United Kingdom
    Scotland
    Ill bet thats seen some life changes throughout the years, Looking forward to seeing it refurbed.
  21. BigStevie
    @Sedgman
    Yes, the mantle is a nice bit of originality. I do have a couple of NOS woven asbestos mantles, though for running probably safer with the mesh mantle.
    @Jacky Young
    It’s some way down the queue, but will get fettled. I usually like to keep originality, in this case it will get polished up as it was originally a lacquered brass finish.
  22. BigStevie
    Looking at the heater fount today, it has the deep hole, so I’m assuming it would have originally had the longer control cock.
  23. Tony Press
    @BigStevie
    You should be able to find the correct period parts. I have a steel tank R1 with that reflector, but it takes the GF control cock.
